I'm extremely new to Linux/command line stuff, so please forgive my ignorance.
Every time I try to install anything using sudo apt-get install ... I get dependency errors. I'm trying to get OpenSSH Server and GitLab installed on my machine, and whenever I type in the commands, I seem to get a dependency error like so:
sudo apt-get install openssh-server
reading package lists... Done
 openssh-server : Depends: libwrap0 (>= 7.6-4~) but it is not installable
                  Recommends: ssh-import-id but it is not installable
I get similar errors seemingly no matter what I try to install. For example, with sudo apt-get install git, the error changes to:
 git : Depends: liberror-perl but it is not installable
I'm running Ubuntu Server 12.04 LTS x86. I've tried doing sudo apt-get clean, sudo apt-get autoclean, sudo apt-get update, and sevveral other similar things. I've tried rebooting, hell, I even wiped out the server and started from scratch with the same issue. I'm sure I'm doing something obviously wrong, but I just can't seem to track it down. If anyone could help, that'd be fantastic.
Update: I did get OpenSSH working by clean installing the server and selecting OpenSSH during set up.
I found this wiki on apt-get so I tried doing sudo apt-get build-dep git and got the error:
E: Build-Depends-Indep dependency for git cannot be satisfied because package asciidoc has no candidate version
I don't know if that helps determine what's happening.
JacobTheDev
  • 1,169
To fix that need to do next actions:
  1. sudo apt-get update
  2. sudo apt-get install -f
  3. sudo rm -rf /var/lib/apt/lists/*
  4. sudo apt-get update
Alex
  • 91
Output of sudo apt-get update which you have provided here has two problem
  1. “Hash sum mismatch” error and
  2. "GPG ERROR"
These two problem is already discussed here( for "Hash sum mismatch") and here (for "GPG ERROR").
Resolving these two error will solve your problem as you are not able to fetch the latest version of software available be in the respective repo.
g_p
  • 19,034
  • 59
  • 69
