I was reinstall Ubuntu, remove Window OS, Format all my HHD and when Im using computer normal, I dont open more program( include: FireFox, Skype), on FireFox I opened 8 tabs. program run in background include Apache, php, mySQL, ibus Unikey.
My computer have structure:
HHD: 1Tb include three partitions (all have Patition type Ext4)
  • swap: /dev/sda1 => 7,2 GB
  • filesystem: /dev/sda2 => 102 GB
  • Extended Partition: /dev/sda3 => 891 GB
    +) Data: /dev/sda5 => 307 GB
    +) Develop: /dev/sda6 => 583 GB
RAM: 2.5GB Main: Gigabyte G41 Chip Core 2 Dou.
the first time, I cant use keybroad, light on keyroad is Off, after about 5 second, light on mouse Off too and I must hard reset computer.
Please help me. I like Linux and I dont want comeback to Window.
Ducnb
  • 13
Warning: You're going to change advanced boot parameters for Ubuntu. Make a system backup first!
  1. Press Ctrl+Alt+T and type the following command:
    gksudo gedit /etc/default/grub
  2. Find the line starting with GRUB_CMDLINE_LINUX_DEFAULT and append atkbd.reset to its end. For example:
    GRUB_CMDLINE_LINUX_DEFAULT="quiet splash atkbd.reset"
    Save the file and close the editor.
  3. Execute the following command:
    sudo update-grub
    to update GRUB's configuration file.
On the next reboot, your problem will be solved.
source
Fabby
  • 35,017
