Read about Keybindings
dconf-editor
dconf-editor > org > gnome > desktop > wm > keybindings
Key bindings are now stored in the dconf registry.
You can install dconf-editor to be able to view and edit them:
sudo add-apt-repository universe
sudo apt-get update
sudo apt-get install dconf-tools
or if you have universe repositories already installed get the package from UbuntuUpdates.org PPA's:
You can also use gsettings command line tool.
For example, to get key binding on the command line:
gsettings get org.gnome.desktop.wm.keybindings switch-windows
or to set a key binding on the command line:
gsettings set org.gnome.desktop.wm.keybindings switch-windows "['<Alt>Tab']"
Keybindings that are handled by the window manager are persisted in the org.gnome.desktop.wm.keybindings section of dconf. The Navigation, and Windows categories of shortcuts are stored here. In the past, each window manager was responsible for storing its own shortcuts under its own schema. Now both the metacity and compiz window managers use this central, unified set of bindings. There are mapping files in /usr/share/gnome-control-center/keybindings/ that show how these key bindings are used by each window manager.
Multiple Keybindings
The keybindings that are handled by the window manager support multiple keys that will perform the same action. The gnome-control-center GUI does not support it, but you can make it work using dconf-editor. For example, to have Close window use both the traditional Alt+F4 as well as an easier to hit Pause/Break button, change:
org.gnome.desktop.wm.keybindings close to ['Pause', '<Alt>F4']
org.gnome.settings-daemon.plugins.media-keys
Shortcuts from the Launchers, Screenshots, Sound and
  media, System, and Custom shortcuts are stored here.
Custom Shortcuts
Custom shortcuts are stored in dconf using a "relocatable schema".
The schema name is org.gnome.settings-daemon.plugins.media-keys.custom-keybinding
Each custom key binding has three properties: name, command, and binding.
Because of the relocatable schema, it is harder to use gsettings with custom shortcuts.
Here is an example of getting the name of the first custom keybinding:
gsettings get org.gnome.settings-daemon.plugins.media-keys.custom-keybinding:/org/gnome/settings-daemon/plugins/media-keys/custom-keybindings/custom0/ name
org.gnome.settings-daemon.plugins.power
Four additional buttons are managed in org.gnome.settings-daemon.plugins.power, they are:
button-hibernate, button-power, button-sleep, and button-suspend.
Possible values are suspend, sleep, hibernate, interactive, and nothing.
These buttons are NOT currently managed by the gnome-control-center.
If you want to reassign the sleep button on your keyboard,
you MUST currently use dconf-editor to assign the button in this section to nothing.
xbindkeys
Also read about Text Entry Shortcuts with xbindkeys
xmodmap
And Mapping Windows Key with xmodmap
Best wishes,
