I got an HP Split x2 with Windows 8 pre-installed. I deleted it, and installed Ubuntu. However, I was wanting to play a few games that didn't work too well on wine, so I created a NTFS partition and installed Win 7 (UEFI) in it.
Windows was overwriting Grub all the time, and after a tiring struggle, I decided to get rid of Windows 7. I deleted its partition, but UEFI would still try to boot into it, which produced a black error screen ("0xc0000225 - The boot selection failed because a required device is inaccessible").
I googled a bit, and was told that Windows 7 installs a bootloader in the first partition. Well, I booted from a live CD, and deleted that partition via GParted. Oh, boy. Apparently, that was the EFI Boot partition, and now my laptop won't boot into anything other than live/install USB drives.
I tried boot-repair, and it told me to create an EFI partition, which I have no idea how to.
Is this fixable? Do I have to format my entire hard drive? The Ubuntu partition is still there (according to GParted), it is just not accessible. Thanks!
MadMike
  • 4,275
  • 29
  • 50
H. Neto
  • 41
Ok, this was tiring, but I fixed it. Here's how:
  1. Create a partition (FAT, first one in hdd, boot flag, 200MiB) via GParted on Ubuntu 14.04 live USB.
  2. Use ALT Linux Rescue / rEFInder live USB to boot into my Ubuntu installation (http://en.altlinux.org/Rescue).
  3. Follow the instructions at (an error occurred while mounting /boot/efi) to fix UUIDs.
  4. Run boot-repair (http://www.howtogeek.com/114884/how-to-repair-grub2-when-ubuntu-wont-boot/).
  5. Reboot the PC.
Thanks for trying to help me, hopefully this will help someone else in the future.
H. Neto
  • 41
First of all, try to make some backups guys, if you don't know how to, search for it first. obviously i didn't, i already had made backups, months before this self-made disaster happened. But don't blame me if you mess things up.
Check here: https://help.ubuntu.com/community/BootPartition. It might work for you as it is, but I had to format that boot partition to FAT32 (instead of ext4) and label it to boot,esp in manage flags before using the recommended option in boot-repair, yep that's the one I used. Good Luck!
I have had same problem, and you try to enter tty, and enter this in terminal:
      sudo apt-get install --force-yes shim-efi-amd64   shim-efi shim-generic
and then enter this in tty:
     grub-install
     update-grub2
     grub-mkconfig
and then enter this in the tty:
     sudo apt-get update
     sudo apt-get install - - reinstall ubuntu-desktop
     sudo dpkg - - reconfigure - a
and it might work fine this way.
Michael
  • 2,597
