I have Ubuntu 14.04, then I don't Know when but I upgrade it until 15.10. Then it's stuck to upgrade 16.10, but the trial result for upgrading is really bad. My Ubuntu can't start. And then(Because that time i need urgently) i re-install other Ubuntu 14.04(old but still LTS), and successfully saved. But accidentally deleted my boot EFI partition. So the windows boot is gone(i replaced it.. T.T ).
The problem is not far from :
Accidentally deleted efi partition
Can't boot after deleting EFI boot- and Windows-partition
Recover windows 10 EFI Boot from dual boot with ubuntu
But idk, how to check where the main problem of mine..
And i was try some other solution too..
Edit for add custom menu
sudo gedit /etc/grub.d/40_custom menuentry "WINDOWS10 (on /dev/sda4)" --class windows --class os { insmod part_msdos insmod ntfs set root='(/dev/sda,msdos1)' search --no-floppy --fs-uuid --set=root 9E1EA0371EA009FB drivemap -s (hd0) ${root} chainloader +1 }stuck :
cant know list msdos1,etcForce for add boot load
sudo grub-install --root-directory=/mnt --boot-directory=/mnt/boot /dev/sda4error :
grub-install: error: cannot find EFI directory.Default re-check
sudo update-grub
stuck :
dummy : do nothing (check additional info in bottom)Recheck UUID :
check with Gparted and boot-repair
still stuck, and say something that point cant with automatically repair, and i didn't understand that.
recheck with boot info script:
sda1: __________________________________________________________________________
File system: vfat
Boot sector type: FAT32
Boot sector info: No errors found in the Boot Parameter Block.
Operating System:
Boot files: /efi/Boot/bootx64.efi /efi/ubuntu/grubx64.efi
/efi/ubuntu/MokManager.efi /efi/ubuntu/shimx64.efi
sda3: __________________________________________________________________________
File system:
Boot sector type: -
Boot sector info:
Mounting failed: mount: unknown filesystem type ''
sda4: __________________________________________________________________________
File system: ntfs
Boot sector type: Windows Vista/7: NTFS
Operating System:
Boot files: /bootmgr /Windows/System32/winload.exe
sda5: __________________________________________________________________________
File system: swap
Boot sector type: -
Boot sector info:
sda6: __________________________________________________________________________
File system: ext3
Boot sector type: -
Boot sector info:
Operating System: Ubuntu 15.10
Boot files: /boot/grub/grub.cfg /etc/fstab
/boot/extlinux/extlinux.conf
sda7: __________________________________________________________________________
File system: ntfs
Operating System:
Boot files:
sda8: __________________________________________________________________________
File system: ext4
Boot sector type: -
Boot sector info:
Operating System: Ubuntu 14.04.5 LTS
============================ Drive/Partition Info: =============================
Drive: sda _____________________________________________________________________
Disk /dev/sda: 500.1 GB, 500107862016 bytes 255 heads, 63 sectors/track, 60801 cylinders, total 976773168 sectors Units = sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes
Partition Boot Start Sector End Sector # of Sectors Id System
/dev/sda1 1 976,773,167 976,773,167 ee GPT
GUID Partition Table detected.
Partition Start Sector End Sector # of Sectors System
/dev/sda1 2,048 1,128,447 1,126,400 EFI System partition
/dev/sda3 1,128,448 1,161,215 32,768 Microsoft Reserved Partition (Windows)
/dev/sda4 1,161,216 219,013,119 217,851,904 Data partition (Windows/Linux)
/dev/sda5 219,013,120 239,493,119 20,480,000 Data partition (Windows/Linux)
/dev/sda6 239,493,120 435,382,271 195,889,152 Data partition (Windows/Linux)
/dev/sda7 468,869,120 976,773,119 507,904,000 Data partition (Windows/Linux)
/dev/sda8 435,382,272 468,869,119 33,486,848 Data partition (Linux)
"blkid" output: ________________________________________________________________
Device UUID TYPE LABEL
/dev/sda1 BAEE-D94B vfat MBR ESP
/dev/sda4 9E1EA0371EA009FB ntfs System
/dev/sda5 f1ce1224-1c07-4b55-8d0e-819ec92966fa swap
/dev/sda6 f89ba19a-53e9-4bb8-b1f3-e98eb3df61db ext3
/dev/sda7 70A6363BA63601E0 ntfs data
/dev/sda8 e3da3fc1-3cfd-49e0-9883-ab4b9f1f56d5 ext4
================================ Mount points: =================================
Device Mount_Point Type Options
/dev/sda1 /boot/efi vfat (rw)
/dev/sda4 /media/reigin/System fuseblk (rw,nosuid,nodev,allow_other,default_permissions,blksize=4096)
/dev/sda6 /media/reigin/f89ba19a-53e9-4bb8-b1f3-e98eb3df61db ext3 (rw,nosuid,nodev,uhelper=udisks2)
/dev/sda7 /media/reigin/data fuseblk (rw,nosuid,nodev,allow_other,default_permissions,blksize=4096)
/dev/sda8 / ext4 (rw,errors=remount-ro)
additional info :
reigin@reigin-K43SA:~/Downloads$ sudo update-grub
Generating grub configuration file ...
Found linux image: /boot/vmlinuz-4.4.0-31-generic
Found initrd image: /boot/initrd.img-4.4.0-31-generic
Found Ubuntu 15.10 (15.10) on /dev/sda6
done
I am still learning how to use Ubuntu, gladly if anyone could help me..
thanks before..
