I'm a new Ubuntu user.
I have UEFI system and after few tries I succeeded to install (via usb), the latest version of ubuntu.
Now when I'm trying to boot from grub i get this message:
an error occurred while mounting /boot/efi
what can i do?
green
  • 14,406
eerez
Type the following commands:
grep efi /etc/fstab
sudo blkid | grep fat
The first command will return information on the EFI System Partition (ESP), as recorded in your /etc/fstab file, which controls automatically-mounted partitions. The second command returns information on all FAT partitions on your computer. The ESP is supposed to be a FAT partition, so you should see some correlations. For instance, here's what I get when I issue these commands on one of my systems:
$ grep efi /etc/fstab
# /boot/efi was on /dev/sda2 during installation
UUID=502D-EB63  /boot/efi       vfat    defaults        0       1
$ sudo blkid | grep fat
/dev/sda2: SEC_TYPE="msdos" LABEL="ESP_FAT16" UUID="502D-EB63" TYPE="vfat"
Note that some systems might return information on two or more FAT partitions from blkid. In such cases, you'll need to figure out which one is your ESP by examining the partition table with gdisk, parted, GParted, or some other partitioning tool. There may be other complications, too, on some systems.
From here, you can look for problems. Pay particular attention to the UUID= values in both outputs. If they don't match, that's the source of the problem. If this is the case, editing /etc/fstab so that it refers to the ESP by its correct filesystem "UUID" (really just a serial number for FAT) should get things working.
Another possible problem won't show up as a discrepancy in the analysis you've just performed, since it's a matter of a filesystem needing repair. You can do this with the dosfsck utility:
sudo dosfsck /dev/sda2
You must pass it the device filename associated with the ESP -- /dev/sda2 in this example, as revealed by the blkid output. After making this repair, the problem should go away, with the caveat that very serious filesystem damage may require more drastic measures, such as backing up the ESP, creating a fresh FAT filesystem on the partition, restoring the data, and adjusting /etc/fstab to use the new "UUID" value.
One more point along these lines: If you're dual-booting with Windows 8, it includes a "fast startup" feature that is basically just a suspend-to-disk feature. Sharing partitions between Windows and Linux with this feature active is almost certain to lead to problems, and I've heard of the ESP being affected by this. Thus, if you're dual-booting with Windows 8, you should disable the fast startup feature. This page describes how to do this in detail.
Rod Smith
  • 45,120
  • 66
  • 108
-3
I was completely lazy and booted a Ubuntu live disk..... once the disk loaded up a desktop, I ran gparted.. I saw that my boot partition /dev/sda1 ext4 with a mount point / had a uuid that looked like a hardware uuid 5465465406546506540d546sd54f66 something like that. (that was a clue to me that.. this was the damaged portion when i had to hard boot when my machine locked up).. I right clicked on said partition made sure it was unmounted and selected check.... thus gparted checked and repaired the partition..... restarted and everything loaded up great... I'm sure it wont work for all cases but it worked for me
Faizan Akram Dar
  • 4,569
  • 25
  • 31
