I'm using Ubuntu 14.04 LTS
I'm trying to update my drivers to the latest version provided by AMD. I couldn't find a way to simply update them, so I decided to uninstall them completely by doing this:
sudo apt-get remove --purge fglrx fglrx-amdcccle fglrx-dev
sudo apt-get remove --purge xserver-xorg-video-ati xserver-xorg-video-radeon
sudo apt-get install xserver-xorg-video-ati
sudo apt-get install --reinstall libgl1-mesa-glx libgl1-mesa-dri xserver-xorg-core
sudo mv /etc/X11/xorg.conf /etc/X11/xorg.conf.backup
sudo rm -rf /etc/ati
Then I rebooted, and ran:
./amd-driver-installer-14.501.1003-x86.x86_64.run
The installer generated the package and I installed it. I then tried to run
aticonfig --initial
but I get the error:
Unable to open /etc/ati/control, please reinstall the driver.
aticonfig: No supported adapters detected
Thinking the installation messed up, I uninstalled the drivers again, rebooted, and tried to install once more. I get the same error. How can I successfully install the drivers?
niznuck
  • 93
Enable support for 32bit packages if you have a 64bit OS -
sudo dpkg --add-architecture i386
Install the following packages -
sudo apt-get install lib32gcc1 libc6-i386
Install all the dependencies listed on this page.
Download all the .deb files related to Ubuntu 14.04 (fglrx,fglrx-core,fglrx-dev and fglrx-amdcccle) from this page.
Copy the downloaded .deb files to a folder.
Now, open a Terminal and cd to the created folder -
cd /path/to/folder
Install the .deb files using dpkg -
sudo dpkg -i *.deb
I have Successfully installed AMD OMEGA Driver by following these steps :
Note: If you previously tried to install any openGL driver "fglrx" purge , autoremove . then reboot your system.
Now follow the steps which i have done to successfully install amd omega driver .
sudo apt-get update
finish the software updater pending list . go to Settings then goto Language and Support if updates there install it . Then click "Apply Syststem wide"
Then sudo apt-get install gksu
Get the amd omega driver for linux from official amd site get amd driver here
after getting amd-catalyst-omega-14.12-linux-run-installers.zip , unzip it
let me consider that file located in Downloads
cd Downloads/
unzip amd-catalyst-omega-14.12-linux-run-installers.zip
cd fglrx-14.501.1003/
sudo chmod +x amd-driver-installer-14.501.1003-x86.x86_64.run
The last action shows some dependency requirement error in /usr/share/ati/fglrx-install.log
NOTE
Even after error AMD Driver Proceed to Install don't do it cancel it .
read the error and then follow the steps given there
cat /usr/share/ati/fglrx-install.log
For me the dependency error showed me to in install the following components
sudo apt-get install debhelper
sudo apt-get install dh-modaliases
sudo apt-get install execstack
apt-get install dpkg-dev
sudo apt-get install dpkg-dev
sudo apt-get install dkms
After installing these Dependency Packages run
it will then follows next next installation , Be patient until it build packages and it install it automatically .
After installation Succesful
sudo reboot
To check whether the installation is Success or not run the following cmds in terminal
fglrxinfo
to Enable AMD Radeon DPM (Dynamic Power Management) Run the Following Cmds
gksu gedit /etc/default/grub
change GRUB_CMDLINE_LINUX_DEFAULT="quiet splash" to GRUB_CMDLINE_LINUX_DEFAULT="quiet splash radeon.dpm=1"
sudo update-grub
Some Tweaks Regarding Brightness Getting Reset Fix (Optional) Read this Fix Brightness Getting Reset (To A Very Low Value Or Maximum) On Reboot In Ubuntu
For Power Management Consider installing this TLP and Laptop Mode
