Installation of newest AMD drivers fails
I tried the steps provided on the above link since it is the closest to the steps provided by AMD in installation instructions and i am still not able to install AMD proprietary driver.
I have a dual Intel/Amd graphics on board
00:02.0 VGA compatible controller: Intel Corporation 2nd Generation Core Processor Family Integrated Graphics Controller (rev 09)
01:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Seymour [Radeon HD 6400M/7400M Series] (rev ff)
I downloaded the following packages from AMD website
$ ls
fglrx_15.201-0ubuntu1_amd64_UB_14.01.deb
fglrx-amdcccle_15.201-0ubuntu1_amd64_UB_14.01.deb
fglrx-core_15.201-0ubuntu1_amd64_UB_14.01.deb
fglrx-dev_15.201-0ubuntu1_amd64_UB_14.01.deb
Then i followed the following steps
Enable support for 32bit packages if you have a 64bit OS -
sudo dpkg --add-architecture i386Install the following packages -
sudo apt-get install lib32gcc1 libc6-i386
$ sudo apt-get install lib32gcc1 libc6-i386
Reading package lists... Done
Building dependency tree
The following NEW packages will be installed:
0 upgraded, 2 newly installed, 0 to remove and 0 not upgraded.
Need to get 2,249 kB of archives.
After this operation, 10.0 MB of additional disk space will be used.
Get:1 http://archive.ubuntu.com/ubuntu/ trusty-updates/main libc6-i386 amd64 2.19-0ubuntu6.9 [2,201 kB]
Get:2 http://archive.ubuntu.com/ubuntu/ trusty-updates/main lib32gcc1 amd64 1:4.9.3-0ubuntu4 [47.8 kB]
Fetched 2,249 kB in 24s (90.7 kB/s)
Selecting previously unselected package libc6-i386.
(Reading database ... 201513 files and directories currently installed.)
Preparing to unpack .../libc6-i386_2.19-0ubuntu6.9_amd64.deb ...
Unpacking libc6-i386 (2.19-0ubuntu6.9) ...
Selecting previously unselected package lib32gcc1.
Preparing to unpack .../lib32gcc1_1%3a4.9.3-0ubuntu4_amd64.deb ...
Unpacking lib32gcc1 (1:4.9.3-0ubuntu4) ...
Setting up libc6-i386 (2.19-0ubuntu6.9) ...
Setting up lib32gcc1 (1:4.9.3-0ubuntu4) ...
Processing triggers for libc-bin (2.19-0ubuntu6.9) ...
Then i tried installing the files by using
sudo dpkg -i *.deb
and got the following error
sudo dpkg -i *.deb
Selecting previously unselected package fglrx.
dpkg: regarding fglrx_15.201-0ubuntu1_amd64_UB_14.01.deb containing fglrx:
xserver-xorg-core-lts-xenial conflicts with fglrx
fglrx (version 2:15.201-0ubuntu1) is to be installed.
dpkg: error processing archive fglrx_15.201-0ubuntu1_amd64_UB_14.01.deb (--install):
conflicting packages - not installing fglrx
Selecting previously unselected package fglrx-amdcccle.
(Reading database ... 201822 files and directories currently installed.)
Preparing to unpack fglrx-amdcccle_15.201-0ubuntu1_amd64_UB_14.01.deb ...
Unpacking fglrx-amdcccle (2:15.201-0ubuntu1) ...
Selecting previously unselected package fglrx-core.
dpkg: regarding fglrx-core_15.201-0ubuntu1_amd64_UB_14.01.deb containing fglrx-core:
xserver-xorg-core-lts-xenial conflicts with fglrx-core
fglrx-core (version 2:15.201-0ubuntu1) is to be installed.
dpkg: error processing archive fglrx-core_15.201-0ubuntu1_amd64_UB_14.01.deb (--install):
conflicting packages - not installing fglrx-core
Selecting previously unselected package fglrx-dev.
Preparing to unpack fglrx-dev_15.201-0ubuntu1_amd64_UB_14.01.deb ...
Unpacking fglrx-dev (2:15.201-0ubuntu1) ...
dpkg: dependency problems prevent configuration of fglrx-amdcccle:
fglrx-amdcccle depends on fglrx; however:
Package fglrx is not installed.
dpkg: error processing package fglrx-amdcccle (--install):
dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of fglrx-dev:
fglrx-dev depends on fglrx-core | fglrx; however:
Package fglrx-core is not installed.
dpkg: error processing package fglrx-dev (--install):
fglrx-amdcccle
fglrx-dev
