35
After installing openssh-server, the server start every time I boot. If I want it to be manual what do I need to do?
In version 0.6.7+ of upstart I would add a "manual" stanza to the job file.
10.04 has upstart 0.6.5-8. What is the preferred way to disable ssh from starting automatically in this case?
Daenyth
  • 768
komputes
  • 3,303
9 Answers9
34
Rename /etc/init/ssh.conf to /etc/init/ssh.conf.disabled.
sudo mv /etc/init/ssh.conf /etc/init/ssh.conf.disabled
Jorge Castro
  • 73,717
komputes
  • 3,303
23
This should be enough,:
 update-rc.d ssh enable # sets the default runlevels to on
 update-rc.d ssh disable # sets all to off
hhlp
  • 42,872
10
In your /etc/init/ssh.conf, comment out the start on line:
# ssh - OpenBSD Secure Shell server
# The OpenSSH server provides secure shell access to the system.
description     "OpenSSH server"
#start on filesystem or runlevel [2345]
stop on runlevel [!2345]
respawn
respawn limit 10 5
umask 022
Bryan Agee
  • 3,376
For system having systemd the proper way to do it is
sudo systemctl disable ssh.service
then
sudo systemctl stop ssh.service
Anwar
  • 77,855
Jocelyn
  • 307
note to the reader:
for me (ubuntu 14.xx) only Bryan Agee's answer worked: /etc/init/ssh.conf: comment out the "start on filesystem or runlevel..." line
why won't the others do?
will result in completly deactivating the service. It is then not startable through "service ssh start" anymore.
does simply not work (perhaps uses different autostart routine)
/etc/init/ssh.conf.override with "manual"
simply doesnt work
touch /etc/ssh/sshd_not_to_be_run
also completly disables the system
sudo apt-get install bum
nice software, but it doesn't show ssh, so nothing to do here
person questioning: why are the above answeres even here? is the start system so complicated or does nobody tries his solutions? oO
Start bum with administrative privileges, disable openssh-server, confirm it, done.
RobinJ
  • 9,020
For versions with ssh started by upstart, run touch /etc/ssh/sshd_not_to_be_run. The upstart init script checks for this file and, if existent, does not start sshd.
Daenyth
  • 768
The manual method provided /etc/init/ssh.config.override method does not work for me using Ubuntu 14.04.03. sshd still starts automatically.
The /etc/ssh/sshd_not_to_be_run method prevents manual sshd start.
I had to use Brian Agee's method of removing the "start on" on line of /etc/init/ssh.conf. Then to manually start sshd:
sudo service ssh start
snoop
  • 4,110
  • 41
  • 58
I had the same question and here's what I did about it. It's a bit of a hack, perhaps, but it works well enough, and you don't need to compromise the program in any way. Put the following in your crontab:
@reboot sudo service ssh stop
This tells cron to stop ssh every time you turn on your computer. Using ssh to connect to another computer isn't affected, as this only turns off the server service. And if you want to re-enable it for a short while, all you have to do is:
Just remember to turn it back off when you're done!
