This is for specified source:
iptables -A INPUT -p tcp --dport ssh -s 10.10.10.10 -j DROP
how to do this for all incoming ssh requests?
There are 2 easy ways to stop someone from being able to ssh to a machine.
1st. with iptables leave off the -s option. That denotes the source. if you use sudo iptables -A INPUT -p tcp --dport ssh -j DROP that will block all connections to port 22.
2nd. as mentioned int he comments stop and disable the openssh-server. There are several ways to do that.
You can uninstall openssh-server,
rename the init.d/ssh.conf,
run update-rc.d ssh disable, or
use the method https://askubuntu.com/a/56849/295286
Provided ufw is install, you can type the following on the terminal:
sudo ufw enable
sudo sudo ufw deny ssh
To check if the firewall is active:
sudo ufw status
You can also block the port ssh is using:
sudo ufw deny 22/tcp
To delete the rule if you don't need it any more:
sudo ufw delete deny ssh
