12
I have a 75 Mbit/s Wifi connection and the Wifi generally works great and fast. Although if I connect to any bluetooth device (e.g. some Audio device) the Wifi suddenly slows down significantly, but I still have a strong signal.
I am currently running Ubuntu 14.10 with Unity on a Dell Vostro V131
Is the bluetooth interfering with the Wifi, or is it a Hardware/Software problem?
If there are any outputs you need to see please let me know.
Thanks in advance!
YumTum
  • 353
There is one thing that might help, and that is to disable bluetooth coexistence in the iwlwifi module
sudo modprobe -r iwlwifi
sudo modprobe iwlwifi bt_coex_active=N
If it works, you can make it persistant with echo "options iwlwifi bt_coex_active=N" | sudo tee -a /etc/modprobe.d/iwlwifi.conf
If it causes problems, just sudo modprobe -r iwlwifi
Jeremy31
  • 13,293
Try hooking your wifi or bluetooth adapter into a USB extension cable and running that away from the other adapter.
I have a Trendnet TBW-105UB bluetooth adapter and a D-Link Dwa 552 wifi adapter and was experiencing this problem until I simply moved the two apart.
Surprisingly, problem resolved.
Credit to @waterlubber for this simple fix. I would have upvoted his comment but don't have the reputation.
Connect first Bluetooth device and than turn on the wifi. It works for me
Vali
