Since upgrading to Ubuntu 13.10, (currently installed 14.04) activating bluetooth makes my wireless extremely slow (halt). I managed to fix the problem recently with the help of this topic: Wifi slows down if I connect with Bluetooth device on Ubuntu 14.10
However, the same problem appeared again today: I can either have bluetooth or wifi but not both at the same time.
Any help would be greatly appreciated!
edit, output of the two commands:
lspci -knn | grep Net -A2
02:00.0 Network controller [0280]: Intel Corporation Centrino Advanced-N 6230 [Rainbow Peak] [8086:0091] (rev 34)
Subsystem: Intel Corporation Centrino Advanced-N 6230 AGN [8086:5201]
Kernel driver in use: iwlwifi
lsusb
Bus 002 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 004: ID 05ca:18c0 Ricoh Co., Ltd
Bus 001 Device 003: ID 08ff:168f AuthenTec, Inc. AES1660 Fingerprint Sensor
Bus 001 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
