While the accepted answer is correct, I often find I am able to find out this info by viewing the changelog of a package, and that is easier than scouring the CVE trackers or security notifications listing. For example:
sudo apt-get update
apt-get changelog ntp
The output of the above command includes:
ntp (1:4.2.6.p5+dfsg-3ubuntu3) vivid; urgency=medium
* SECURITY UPDATE: weak default key in config_auth()
- debian/patches/CVE-2014-9293.patch: use openssl for random key in
ntpd/ntp_config.c, ntpd/ntpd.c.
- CVE-2014-9293
* SECURITY UPDATE: non-cryptographic random number generator with weak
seed used by ntp-keygen to generate symmetric keys
- debian/patches/CVE-2014-9294.patch: use openssl for random key in
include/ntp_random.h, libntp/ntp_random.c, util/ntp-keygen.c.
- CVE-2014-9294
* SECURITY UPDATE: buffer overflows in crypto_recv(), ctl_putdata(), configure()
- debian/patches/CVE-2014-9295.patch: check lengths in
ntpd/ntp_control.c, ntpd/ntp_crypto.c.
- CVE-2014-9295
* SECURITY UPDATE: missing return on error in receive()
- debian/patches/CVE-2015-9296.patch: add missing return in
ntpd/ntp_proto.c.
- CVE-2014-9296
-- Marc Deslauriers <marc.deslauriers@ubuntu.com> Sat, 20 Dec 2014 05:47:10 -0500
Which clearly shows that the bugs you mentioned have been fixed in the ubuntu repositories. You can then run:
sudo apt-get upgrade
to pull down the fix.
