The bug has been patched in the Linux kernel 5.0.8 version, according to the news. What about the kernel version 4.15.0-50-generic? How to check a given kernel to find out whether CVE-2019-11815 has been patched? How to patch the CVE-2019-11815 bug in Ubuntu 18.04.2 LTS with the kernel version 4.15.0-50-generic?
This affects all Linux kernels prior to 5.0.8 — therefore, it will affect version 4.15.0. It is currently being patched by the Ubuntu security team. For more details, check out the Ubuntu CVE Tracker page on CVE-2019-11815.
- 421
This question has been nagging me for a long time: How do I map Linux Kernels to Ubuntu Kernels? Unfortunately I'm no closer today to that answer than I was back then.
So below is my best guess for you.
Go to: https://kernel.ubuntu.com/~kernel-ppa/mainline and sort by date by clicking column header. Sort again for descending order and scroll until you see 5.0.8:
- Everything released after
5.0.8will presumably have CVE-2019-11815 patch applied. 5.0.8was compiled on the Ubuntu Kernel Farm on April 15, 2019.- Personally I've downloaded and installed
4.14.114LTS kernel compiled on April 27, 2019 so it would have the patch applied.
So the big question is what date was your kernel 4.15.0-50 compiled?
Look in /boot directory at my 4.14.114 as an example:
$ ll /boot/*4.14.114*
-rw-r--r-- 1 root root 213788 Apr 27 04:08 /boot/config-4.14.114-0414114-generic
-rw-r--r-- 1 root root 63203180 Apr 29 19:43 /boot/initrd.img-4.14.114-0414114-generic
-rw------- 1 root root 3983979 Apr 27 04:08 /boot/System.map-4.14.114-0414114-generic
-rw------- 1 root root 8681248 May 12 10:37 /boot/vmlinuz-4.14.114-0414114-generic
Firstly ignore /boot/vmlinuz-4.14.114-0414114-generic because my grub boot flags the last time each kernel was booted so the date May 12 2019 is bogus for your purpose.
The file /boot/vmlinuz-4.14.114-0414114-generic or /boot/System.map-4.14.114-0414114-generic should tell you the time your kernel was released. If after April 15, 2019 you should have the desired patch applied.
The remaining file /boot/initrd.img-4.14.114-0414114-generic should be the date the kernel was installed on your system.
Of course you will replace 4.14.114 above with 4.15.0!!!
There is also a publication linking Ubuntu kernel release numbers to stable Linux kernel release numbers but I find it confusing. If you figure it out please post an answer.
- 105,762
You can see the change log of this update on https://launchpad.net/ubuntu/+source/linux/4.15.0-50.54
- 26
- 1
