When you type sh somescript.sh, the system looks for sh in the path not somescript.sh.
Then the system finds sh and passes the argument somescript.sh to it. Then sh looks for somescript.sh in the current folder or in the specified folder ~/bin/ if you typed
sh ~/bin/somescirpt.sh.
To make the system look for somescript.sh in the path use it directly as a command, without the sh prefix. In other words, type in the terminal:
somescript.sh
For that to work, somescript.sh needs located in a folder in the path, in this case ~/bin/ and it needs to be executable, as others have pointed out. I include the command below for completeness.
chmod +x ~/bin/somescript.sh
Also see How do I run .sh files? and
How to run scripts without typing the full path?
Hope this helps
