I use win7 + ubuntu 14.04.
I'm not sure how to cause this problem.
The situation is I can see boot menu with win7 but without working.
When I press enter on win7, it splash and show the same menu again to let me choose.
What's this situation?
How to fixed it?
Thank you~
LiveWireBT
  • 29,597
sam
  • 6,921
first try this:
  • insert your windows 7 instalation cd/dvd and boot from. choose your language and hit next. when prompted to "install now" appear just look left down to that windos and press repair your computer.
  • wait and a new windows rise with operatings system instaled in your pc. click on "windows 7" and hit next.
  • in the next window press "Command "Prompt". when command prompt window appear type that:
    bootrec /fixboot
    press enter and:
    bootrec /fixmbr
  • press enter again and then close that command prompt window and restart your pc. Note: between "bootrec" and "/" there is a space, dont forget.
  • After that i think you will no longer have option to choose between operating systems to boot on startup. you will must to repair grub.( i think you can do that with ubuntu live cd. but i am not sure. Good luck. Let me know if you fix that. (Easy way is after repair windows 7 boot format the linux partition and reinstall linux:D)
Note :
01/20/2019
To repair grub after fix windows 7 boot:
Try this.. To recover grub: 1.Open the live version.
2.Open the terminal and run sudo fdisk -l to see where Linux is installed.
3.Run: sudo mount /dev/sdaX /mnt where X is the number you have found Linux word in
4.Run: sudo grub-install --root-directory=/mnt /dev/sda
to install grub.
5.Run: sudo update-grub to update grub, and if this command didn't work run it after rebooting.
6.Reboot.
Note:
For me #5 command didn't work. So i restart the computer and after restart, computer boot directly in to ubuntu O.S. So i loged as root and write this command:
sudo update-grub
That solve the problem. EugenB
eugen
  • 56
