Use a text editor as root and manually edit the /etc/group file. Look for the line that says audio and add your username to the end.
This is how the line looked before I edited it:
audio:x:29:
This is how the line looked after I edited it:
audio:x:29:username
Save the file and logout, then log back in and test sound. If it doesn't work try rebooting just to make sure changes are applied and test audio again.
Don't forget to celebrate!
If you still can't hear audio, make sure your Master Volume is not muted. Install alsa-utils which will install alsamixer so you can control your soundcard (volume, mute, boost, choose card, etc.) Run alsamixer in a terminal by typing alsamixer and use your arrow keys to raise the volumes.
You can't run alsamixer as a normal user until you add yourself to the audio group. Even if you run alsamixer as root and your system was on mute and you raise the volume to the max, you still will not hear any audio until you've successfully added yourself to the audio group. The key to getting sound in a minimal install is adding yourself to the audio group.
Note: I never installed pulseaudio to my system. Don't know if that changes things. If it does: try purging pulseaudio from your system first, then install alsa-utils and follow the instructions I gave at the top to add yourself to the audio group.
Going off on a tangent: This is the first minimal install I do so I'm learning a hell of a lot about how ubuntu works. I'll tell you this: I have a deeper appreciation for distros with gui's & desktop environments and the people who make them. It's a hell of a lot work to build a friendly system with all the essential tools and programs. Just wrapping your mind around some of these concepts will keep you up for days. That being said I have a sneaking suspicion there's a lot of other groups you may have to add yourself to to get things to work in a minimal install.
For example, I haven't tested out google voice yet but I may have to add myself to the voice group. We'll see. By default a user is not automatically added to a lot of groups in the minimal install. Hey we wanted to start from scratch and make all the decisions right. Well... here we go.
Happy building!
