I'm using ubuntu-mini-remix to build a network-booting live OS which loads a remote desktop client and logs users into their virtual desktop environments.
I've gotten everything to work except the audio.
On top of Ubuntu-mini-remix 14.04 I have the following packages installed:
xorg --no-install-recommends
nodm --no-install-recommends
lxde --no-install-recommends
pulseaudio
alsa-base
hptc-manticore_3.2.1_i386
hptc-rdesktop_1.6.0-1.35_i386
vmware-horizon-view-client_2.3.0-_i386-modified
I added the live user 'ubuntu' to the groups audio, pulse, and pulse-access
aplay -l
card0: Intel [HDA Intel], device 0: STAC9228 Analog [STAC9228 Analog]
Subdevices: 1/1
Subdevices #0: subdevice #0
card0: Intel [HDA Intel], device 1: STAC9228 Digital [STAC9228 Digital]
Subdevices: 1/1
Subdevice #0: subdevice #0
find /lib/modules/`uname -r` | grep snd
finds a ton of modules and
lspci -v | grep -A7 -i "audio"
finds
00:1b.0 Audio device: Intel Corporation 82801H (ICH8 Family) HD Audio Controller
Subsystem: Dell Device 0209
Flags: bus master, fast devsel, latency 0, IRQ 48
Memory at f6ffc000 (64-bit, non-prefetchable) [size=16K]
Capabilities: <access denied>
Kernel driver in use: snd_hda_intel
both
aplay /usr/share/sounds/alsa/Front_Center.wav
and
sudo aplay /usr/share/sounds/alsa/Front_Center.wav
play nothing
I have everything unmuted and turned up in alsamixer
I don't have a audio system tray icon but I assume I don't need one
Any insight?
I did nearly the same build on lubuntu live 14.04 and the audio worked fine on all of the same hardware, so I figure I'm missing drivers, modules, packages, or something
thanks
DevinV
It was a matter of adding the live user created on boot to the audio group, it was in one of the casper scripts, I'm not sure which one, but a google search for adding the casper live user to a group should put you in the right direction
EDIT:
Sorry, its a simple fix, I was just in a hurry when I responded
in the unpacked rootfs of the live system, you just need to edit the file /etc/adduser.conf such that the adduser command adds the audio group by default.
in the file, make sure to add or edit the ADD_EXTRA_GROUPS line such that it reads:
ADD_EXTRA_GROUPS=1
and there may or may not be a line which is commented out which lists the extra groups to be added, you may add whichever groups youd like but for just the audio, edit such that it reads:
EXTRA_GROUPS="audio"
to add multiple groups just separate them with spaces within the quotes, like:
EXTRA_GROUPS="audio video plugdev"
DevinV
