18
I havent used my Ubuntu for quite a long time. Today, when I booted Ubuntu (14.04 LTS), the software updater and Software & Updates (from Settings) are not working.
The software updater's window will show up for around 1 sec, but it will close automatically. Software & Updates is never shown, no matter how many times I click the icon. Note that neither of them show any error message.
Those 2 features were working perfectly the last time I used Ubuntu. I want to do some system upgrade and update.
For now, I use sudo apt-get update && sudo apt-get upgrade. This command runs very fast, meaning (I think) my Ubuntu is not updated properly. The update from software updater always has a big size hence the download should be slower.
What should I do?
Can I just uninstall and reinstall both of them? If I can, how to do it?
Just to clarify, I don't want to upgrade my Ubuntu version (I want the LTS one), I just want to upgrade the software/packages I used.
Thanks for your time.
Zanna
  • 72,312
This is a common thing which is simply solved. These commands clear the "phantom" or "hung" lists and may have to be used again as needed in the future for similar bug:
sudo rm -rvf /var/lib/apt/lists/*
and then:
sudo apt-get update
You may need to reboot computer for it to effect completely by typing:
sudo shutdown -r now
Alex Jones
  • 8,192
Candu
  • 307
I have almost exactly the same problem as @Blaze Tama and the answer proposed by @Candu and @edward torvalds did not fix it.
I do not get any error message but when I click on the icons of Software updater and Software & Updates, nothing happens. And Software updater does not prompt me for updates any more.
I am not completely sure that it is the same bug because the sudo apt-get update && sudo apt-get upgrade command seems to work fine for me.
My solution:
  1. Make sure that it is the same bug by running:
/usr/bin/update-manager
My solution should work if your error is:
Traceback (most recent call last):
  File "./update-manager", line 37, in <module>
    from UpdateManager.UpdateManager import UpdateManager
  File "/usr/lib/python3/dist-packages/UpdateManager/UpdateManager.py", line 43, in <module>
    import dbus
  File "/usr/lib/python3/dist-packages/dbus/__init__.py", line 103, in <module>
    from dbus._dbus import Bus, SystemBus, SessionBus, StarterBus
  File "/usr/lib/python3/dist-packages/dbus/_dbus.py", line 39, in <module>
    from dbus.bus import BusConnection
  File "/usr/lib/python3/dist-packages/dbus/bus.py", line 39, in <module>
    from dbus.connection import Connection
  File "/usr/lib/python3/dist-packages/dbus/connection.py", line 27, in <module>
    import threading
ImportError: No module named 'threading'
  1. Download the module 'threading' in your version of Python3
The source code for Python3.4 can be found at https://hg.python.org/cpython/file/3.4/Lib/threading.py . And should be saved in the folder /usr/lib/python3.4. (Or what ever your version of Python3 is. Be careful, in my case, I had this module for Python2.7 but not for Python3.4!)
PS: This bug was described here: https://bugs.launchpad.net/elementaryos/+bug/1415128
Prolix
  • 365
Try the following :
sudo apt remove update-manager
sudo apt autoremove -y
sudo rm -r /usr/bin/update-manager
sudo apt install update-manager
sudo apt update
wbadry
  • 270
I had the similar problem in Ubuntu 20.04 when trying to turn off annoying pop up notifications for updates. One of recommendations was to uncheck all check boxes, (sources for updates) on "Ubuntu Software" tab and "Other Software" tab (first two tabs) in "Software & Updates" program.
This can lead to hanging of "Software & Updates" (software-properties-gtk) and "Software Update" (update-manager) programs.
Windows of this programs can be closed with "Quit" button. But their processes will continue to work. It is not possible to run this programs again before killing their hanging processes.
ps auxww | grep update
# "Software Update" is update-manager
user   325722  2.7  1.1 713212 87460 ?        Sl   20:33   0:01 /usr/bin/python3 /usr/bin/update-manager
ps auxww | grep software
# "Software & Updates" is software-properties-gtk
user    34816  0.4  1.1 820040 92888 ?        Sl   18:29   0:27 /usr/bin/python3 /usr/bin/software-properties-gtk
root       34829  0.1  0.6 267436 49460 ?        Sl   18:29   0:06 python3 /usr/lib/software-properties/software-properties-dbus
To kill the processes commands like kill 34816, kill 325722 are used.
In my case after this, "Software & Updates" and "Software Update" can be run normally again.
