I can't seem to get “Software & Updates” Application to appear after clicking on it. I don't know why. It's icon appears in the shortcut. What is the terminal command to activate this App?
I have tried this answer: “Software Updater” & “Software & Updates” not working, but it did not work.
$ uname -a
Linux Ubuntu 5.4.0-42-generic #46~18.04.1-Ubuntu SMP Fri Jul 10 07:21:24 UTC 2020 x86_64 x86_64 x86_64 GNU/Linux
$ gnome-shell --version GNOME Shell 3.28.4
$ software-properties-gtk ERROR:dbus.proxies:Introspect error on :1.228:/: dbus.exceptions.DBusException: org.freedesktop.DBus.Error.NoReply: Message recipient disconnected from message bus without replying Traceback (most recent call last): File "/usr/bin/software-properties-gtk", line 100, in <module> app = SoftwarePropertiesGtk(datadir=options.data_dir, options=options, file=file) File "/usr/lib/python3/dist-packages/softwareproperties/gtk/SoftwarePropertiesGtk.py", line 173, in init self.backend.Reload(); File "/usr/lib/python3/dist-packages/dbus/proxies.py", line 70, in call return self._proxy_method(args, keywords) File "/usr/lib/python3/dist-packages/dbus/proxies.py", line 145, in call *keywords) File "/usr/lib/python3/dist-packages/dbus/connection.py", line 651, in call_blocking message, timeout) dbus.exceptions.DBusException: org.freedesktop.DBus.Error.ServiceUnknown: The name :1.228 was not provided by any .service files
I also have the same msgs as in Ubuntu 18.04 software-properties-gtk failing with org.freedesktop.DBus.Error.ServiceUnknown. I used Synaptic to reinstall the package python3-size as was mentioned in this answer but to no avail.
I had also tried purging and reinstalling software-properties-gtk as was mentioned here but to no avail.
Update1:
I wonder if setuptools.py ver 50.0 broke software-properties-gtk's connection? I know that the system had this upgraded yesterday from ver 42.0.2. I just found this GitHub issue "setuptools 50 breaks pip installation" which was raised 22 hours ago. I have uninstalled it but to no avail.
Update 2: Using journalctl -e cmd in the terminal, I found this error msg:
Oct 04 08:22:14 Prime dbus-daemon[1303]: [system] Activating service name='com.ubuntu.SoftwareProperties' requested by ':1.157' (uid=1000 pid=10808 comm="/usr/bin/python3 /usr/bin/soft
Oct 04 08:22:14 Prime com.ubuntu.SoftwareProperties[1303]: Unable to init server: Could not connect: Connection refused
Oct 04 08:22:14 Prime dbus-daemon[1303]: [system] Successfully activated service 'com.ubuntu.SoftwareProperties'
Oct 04 08:22:14 Prime com.ubuntu.SoftwareProperties[1303]: Traceback (most recent call last):
Oct 04 08:22:14 Prime com.ubuntu.SoftwareProperties[1303]:   File "/usr/lib/software-properties/software-properties-dbus", line 68, in <module>
Oct 04 08:22:14 Prime com.ubuntu.SoftwareProperties[1303]:     server = SoftwarePropertiesDBus(bus, datadir=datadir)
Oct 04 08:22:14 Prime com.ubuntu.SoftwareProperties[1303]:   File "/usr/lib/python3/dist-packages/softwareproperties/dbus/SoftwarePropertiesDBus.py", line 66, in __init__
Oct 04 08:22:14 Prime com.ubuntu.SoftwareProperties[1303]:     self._livepatch_service = LivepatchService()
Oct 04 08:22:14 Prime com.ubuntu.SoftwareProperties[1303]:   File "/usr/lib/python3/dist-packages/softwareproperties/LivepatchService.py", line 93, in __init__
Oct 04 08:22:14 Prime com.ubuntu.SoftwareProperties[1303]:     self._session = requests_unixsocket.Session()
Oct 04 08:22:14 Prime com.ubuntu.SoftwareProperties[1303]: NameError: name 'requests_unixsocket' is not defined
Also, the python package 'requests_unixsocket' is installed in the system(see below). Hence I don't understand the error msg NameError: name 'requests_unixsocket' is not defined:
$ pip list | grep requests
requests                2.24.0
requests-unixsocket     0.1.5
WARNING: You are using pip version 20.2.2; however, version 20.2.3 is available.
You should consider upgrading via the '/usr/bin/python3 -m pip install --upgrade pip' command.
$ pip3 list | grep requests
requests                2.24.0
$ pip3 list --user | grep requests
requests            2.24.0
I have tried to import requests_unixsocket explicitly. It works. See below.
Python 3.6.9 (default, Jul 17 2020, 12:50:27)
[GCC 8.4.0] on linux
Type "help", "copyright", "credits" or "license()" for more information.
>>> a = requests_unixsocket.Session()
>>> a
<requests_unixsocket.Session object at 0x7fb103952470>
I don't understand why I can import the package but /usr/lib/python3/dist-packages/softwareproperties/LivepatchService.py can't see it. It does exist:
$ ls /usr/lib/python3/dist-packages/ | grep request
requests_unixsocket
requests_unixsocket-0.1.5.egg-info
Sun Bear
  • 3,014
I am on Ubuntu 20.04 and I experienced this problem. I tried the posts that recommended reinstalling python3-six and python3-certifi, but those didn't work for me. However, software-properties-gtk did start working again for me after I reinstalled python3-requests and python3-idna. So, to sum up the commands I ran:
sudo apt install --reinstall python3-six python3-certifi python3-requests python3-idna
sudo apt install --reinstall software-properties-gtk
and I was back in business.
Same problem on Ubuntu 20.10... I had a look to dbus messages:
sudo systemctl status dbus.service
and saw this line:
.../... com.ubuntu.SoftwareProperties[8310]: ModuleNotFoundError: No module named 'chardet'
So I reinstalled chardet:
sudo apt install --reinstall python3-chardet
and software-properties-gtk is back.
The log shows:
dbus-daemon[1130]: [system] Successfully activated service 'com.ubuntu.SoftwareProperties'
Hope it helps.
