45
How can I encode and decode percent-encoded (URL encoded) strings on the command line?
I'm looking for a solution that can do this:
$ percent-encode "ændrük"
%C3%A6ndr%C3%BCk
$ percent-decode "%C3%A6ndr%C3%BCk"
ændrük
ændrük
  • 78,496
8 Answers8
45
These commands do what you want (using Python 2):
python -c "import urllib, sys; print urllib.quote(sys.argv[1])" æ
python -c "import urllib, sys; print urllib.unquote(sys.argv[1])" %C3%A6
If you want to encode spaces as +, replace urllib.quote with urllib.quote_plus.
I'm guessing you will want to alias them ;-)
Pablo Bianchi
  • 17,371
41
shell
Try the following command line:
$ echo "%C3%A6ndr%C3%BCk" | sed 's@+@ @g;s@%@\\x@g' | xargs -0 printf "%b"
ændrük
You may define it as alias and add it to your shell rc files:
$ alias urldecode='sed "s@+@ @g;s@%@\\\\x@g" | xargs -0 printf "%b"'
Then every time when you need it, simply go with:
$ echo "http%3A%2F%2Fwww" | urldecode
http://www
bash
When scripting, you can use the following syntax:
input="http%3A%2F%2Fwww"
decoded=$(printf '%b' "${input//%/\\x}")
However above syntax won't handle pluses (+) correctly, so you've to replace them with spaces via sed.
You can also use the following urlencode() and urldecode() functions:
urlencode() {
    # urlencode <string>
    local length="${#1}"
    for (( i = 0; i < length; i++ )); do
        local c="${1:i:1}"
        case $c in
            [a-zA-Z0-9.~_-]) printf "$c" ;;
            *) printf '%%%02X' "'$c"
        esac
    done
urldecode() {
    # urldecode <string>
    local url_encoded="${1//+/ }"
    printf '%b' "${url_encoded//%/\\x}"
Note that your urldecode() assumes the data contains no backslash.
bash + xxd
Bash function with xxd tool:
urlencode() {
    local c="${1:i:1}"
    case $c in
    *) printf "$c" | xxd -p -c1 | while read x;do printf "%%%s" "$x";done
  esac
done
Found in cdown's gist file, also at stackoverflow.
Python
Try to define the following aliases:
alias urldecode='python -c "import sys, urllib as ul; print ul.unquote_plus(sys.argv[1])"'
alias urlencode='python -c "import sys, urllib as ul; print ul.quote_plus(sys.argv[1])"'
Usage:
$ urlencode "ændrük"
C%26ndrC%3Ck
$ urldecode "%C3%A6ndr%C3%BCk"
ændrük
Source: ruslanspivak
PHP
Using PHP you can try the following command:
$ echo oil+and+gas | php -r 'echo urldecode(fgets(STDIN));' // Or: php://stdin
oil and gas
or just:
php -r 'echo urldecode("oil+and+gas");'
Use -R for multiple line input.
Perl
In Perl you can use URI::Escape.
decoded_url=$(perl -MURI::Escape -e 'print uri_unescape($ARGV[0])' "$encoded_url")
Or to process a file:
perl -i -MURI::Escape -e 'print uri_unescape($ARGV[0])' file
sed
Using sed can be achieved by:
cat file | sed -e's/%\([0-9A-F][0-9A-F]\)/\\\\\x\1/g' | xargs echo -e
awk
Try anon solution:
awk -niord '{printf RT?$0chr("0x"substr(RT,2)):$0}' RS=%..
See: Using awk printf to urldecode text.
decoding file names
If you need to remove url encoding from the file names, use deurlname tool from renameutils (e.g. deurlname *.*).
See also:
Related:
kenorb
  • 10,944
10
Pure bash solution for decoding only:
$ a='%C3%A6ndr%C3%BCk'
$ echo -e "${a//%/\\x}"
ændrük
loentar
  • 201
10
Percent-encode reserved URI characters and non-ASCII characters
jq -s -R -r @uri
-s (--slurp) reads input lines into an array and -s -R (--slurp --raw-input) reads the input into a single string. -r (--raw-output) outputs the contents of strings instead of JSON string literals.
Percent-encode all characters
xxd -p|tr -d \\n|sed 's/../%&/g'
tr -d \\n removes the linefeeds that are added by xxd -p after every 60 characters.
Percent-encode all characters except ASCII alphanumeric characters in Bash
eu () {
    local LC_ALL=C c
    while IFS= read -r -n1 -d '' c
    do
        if [[ $c = [[:alnum:]] ]]
        then
            printf %s "$c"
        else
            printf %%%02x "'$c"
        fi
    done
Without -d '' this would skip linefeeds and null bytes. Without IFS= this would replace characters in IFS with %00. Without LC_ALL=C this would for example replace with %3042 in a UTF-8 locale.
muru
  • 207,228
nisetama
  • 791
Similar to Stefano answer but with Python 3:
python3 -c "import urllib.parse, sys; print(urllib.parse.quote(sys.argv[1]))" æ         # to percent-enconding
python3 -c "import urllib.parse, sys; print(urllib.parse.unquote(sys.argv[1]))" %C3%A6  # from percent-enconding
To encode also slashes:
python3 -c "import urllib.parse, sys; print(urllib.parse.quote(sys.argv[1] if len(sys.argv) > 1 else sys.stdin.read()[0:-1], \"\"))"
More info about the difference here.
Pablo Bianchi
  • 17,371
I can't comment on best answer in this thread, so here is mine.
Personally, I use these aliases for URL encoding and decoding:
alias urlencode='python -c "import urllib, sys; print urllib.quote(  sys.argv[1] if len(sys.argv) > 1 else sys.stdin.read()[0:-1])"'
alias urldecode='python -c "import urllib, sys; print urllib.unquote(sys.argv[1] if len(sys.argv) > 1 else sys.stdin.read()[0:-1])"'
Both commands allow you to convert data, passed as a command line argument or read it from standard input, because both one-liners check whether there are command line arguments (even empty ones) and process them or just read standard input otherwise.
update 2015-07-16 (empty 1st arg)
... according to @muru comment.
update 2017-05-28 (slash encoding)
If you also need to encode the slash, just add an empty second argument to the quote function, then the slash will also be encoded.
So, finally urlencode alias in bash looks like this:
alias urlencode='python -c "import urllib, sys; print urllib.quote(sys.argv[1] if len(sys.argv) > 1 else sys.stdin.read()[0:-1], \"\")"'
Example
$ urlencode "Проба пера/Pen test"
%D0%9F%D1%80%D0%BE%D0%B1%D0%B0%20%D0%BF%D0%B5%D1%80%D0%B0%2FPen%20test
$ echo "Проба пера/Pen test" | urlencode
$ urldecode %D0%9F%D1%80%D0%BE%D0%B1%D0%B0%20%D0%BF%D0%B5%D1%80%D0%B0%2FPen%20test
Проба пера/Pen test
$ echo "%D0%9F%D1%80%D0%BE%D0%B1%D0%B0%20%D0%BF%D0%B5%D1%80%D0%B0%2FPen%20test" | urldecode
Проба пера/Pen test
$ urlencode "Проба пера/Pen test" | urldecode
Проба пера/Pen test
$ echo "Проба пера/Pen test" | urlencode | urldecode
Проба пера/Pen test
DIG mbl
  • 163
I found a package, renameutils, that contain the utility deurlname that is able to rename a file containing "percent-encoded" characters.
Unfortunately, it does not decode stdin or a command line option, but only rename a file, so you have to create a dummy file to obtain the decoding (the name of the renamed file), but with some bash scripting the process can be automated.
No information about the encoding part, even because it could be questionable which characters to encode. Only non-ASCII?
I think there should be some better tool/method.
enzotib
  • 96,093
Here is a POSIX Awk function for encoding:
function encodeURIComponent(str, j, q) {
  while (y++ < 125) z[sprintf("%c", y)] = y
  while (y = substr(str, ++j, 1))
    q = y ~ /[[:alnum:]_.!~*\47()-]/ ? q y : q sprintf("%%%02X", z[y])
  return q
Example
Zombo
