When I try to upgrade via terminal using sudo apt-get upgrade this error appears:
Reading package lists... Done
Building dependency tree
Package 'linux-image-3.13.0-27-generic' is not installed, so not removed
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
5 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Setting up linux-image-3.13.0-37-generic (3.13.0-37.64) ...
Running depmod.
update-initramfs: deferring update (hook will be called later)
Not updating initrd symbolic links since we are being updated/reinstalled
(3.13.0-37.64 was configured last, according to dpkg)
Not updating image symbolic links since we are being updated/reinstalled
Examining /etc/kernel/postinst.d.
run-parts: executing /etc/kernel/postinst.d/apt-auto-removal 3.13.0-37-generic /boot/vmlinuz-3.13.0-37-generic
run-parts: executing /etc/kernel/postinst.d/dkms 3.13.0-37-generic /boot/vmlinuz-3.13.0-37-generic
run-parts: executing /etc/kernel/postinst.d/initramfs-tools 3.13.0-37-generic /boot/vmlinuz-3.13.0-37-generic
update-initramfs: Generating /boot/initrd.img-3.13.0-37-generic
run-parts: executing /etc/kernel/postinst.d/update-notifier 3.13.0-37-generic /boot/vmlinuz-3.13.0-37-generic
run-parts: executing /etc/kernel/postinst.d/zz-extlinux 3.13.0-37-generic /boot/vmlinuz-3.13.0-37-generic
P: Checking for EXTLINUX directory... found.
P: Writing config for /boot/vmlinuz-3.13.0-37-generic...
P: Installing debian theme...cp: cannot stat ‘/usr/share/syslinux/themes/debian-wheezy/extlinux/memtest.bin’: No such file or directory
run-parts: /etc/kernel/postinst.d/zz-extlinux exited with return code 1
Failed to process /etc/kernel/postinst.d at /var/lib/dpkg/info/linux-image-3.13.0-37-generic.postinst line 1025.
dpkg: error processing package linux-image-3.13.0-37-generic (--configure):
subprocess installed post-installation script returned error exit status 2
dpkg: dependency problems prevent configuration of linux-image-extra-3.13.0-37-generic:
linux-image-extra-3.13.0-37-generic depends on linux-image-3.13.0-37-generic; however:
Package linux-image-3.13.0-37-generic is not configured yet.
dpkg: error processing package linux-image-extra-3.13.0-37-generic (--configure):
dependency problems - leaving unconfigured
No apport report written because the error message indicates its a followup error from a previous failure.
dpkg: dependency problems prevent configuration of linux-image-generic:
linux-image-generic depends on linux-image-3.13.0-37-generic; however:
linux-image-generic depends on linux-image-extra-3.13.0-37-generic; however:
Package linux-image-extra-3.13.0-37-generic is not configured yet.
dpkg: error processing package linux-image-generic (--configure):
dpkg: dependency problems prevent configuration of linux-generic:
linux-generic depends on linux-image-generic (= 3.13.0.37.44); however:
Package linux-image-generic is not configured yet.
dpkg: error processing package linux-generic (--configure):
No apport report written because MaxReports is reached already
dpkg: dependency problems prevent configuration of linux:
linux depends on linux-generic; however:
Package linux-generic is not configured yet.
dpkg: error processing package linux (--configure):
To solve the problem I tried
- I get this error after upgade. please help
- Accidentally deleted the "linux-image-generic"
- Unmet dependencies when trying to update
- dpkg opporations fail: Failed to run depmod, error processing linux-image-generic
- libpam systemd - installation error ubuntu 14.04 unable to install updates
- "apt-get -f install" fails with "/usr/bin/dpkg returned an error code (1)"
- Fixing software center catalog
- dpkg: error processing package linux-image-generic (--configure): dependency problems - leaving unconfigured
This is my /etc/grub.d/00_header content.
What should I do?
