Possible Duplicate:
Fixing Broken Packages
I started out trying to install CVS:
$ sudo apt-get install cvs
Reading package lists... Done
Building dependency tree
You might want to run 'apt-get -f install' to correct these:
 libcups2 : Breaks: libcups2:i386 (!= 1.5.3-0ubuntu3) but 1.5.3-0ubuntu4 is to be installed
 libcups2:i386 : Breaks: libcups2 (!= 1.5.3-0ubuntu4) but 1.5.3-0ubuntu3 is to be installed
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
But when I try this I get:
$ sudo apt-get -f install
Correcting dependencies... Done
The following package was automatically installed and is no longer required:
  tzdata-java
Use 'apt-get autoremove' to remove them.
The following extra packages will be installed:
  libcups2
The following packages will be upgraded:
  libcups2
1 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
14 not fully installed or removed.
Need to get 0 B/172 kB of archives.
After this operation, 0 B of additional disk space will be used.
Do you want to continue [Y/n]? y
dpkg: error processing libcups2 (--configure):
 libcups2:amd64 1.5.3-0ubuntu3 cannot be configured because libcups2:i386 is in a different version (1.5.3-0ubuntu4)
dpkg: error processing libcups2:i386 (--configure):
 libcups2:i386 1.5.3-0ubuntu4 cannot be configured because libcups2:amd64 is in a different version (1.5.3-0ubuntu3)
dpkg: dependency problems prevent configuration of libcupsmime1:
 libcupsmime1 depends on libcups2 (>= 1.5~); however:
  Package libcups2 is not configured yet.
dpkg: error processing libcupsmime1 (--configure):
 dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of libcupscgi1:
 libcupscgi1 depends on libcups2 (>= 1.4.0); however:
dpkg: error processing libcupscgi1 (--configure):
dpkg: dependency problems prevent configuration of libcupsppdc1:
 libcupsppdc1 depends on libcups2 (>= 1.4.0); however:
dpkg: error processing libcupsppdc1 (--configure):
dpkg: dependency problems prevent configuration of cups-client:
 cups-client depends on libcups2 (>= 1.5.0); however:
dpkg: error processing cups-client (--configure):
 dependency problems - leaviNo apport report written because the error message indicates its a followup error from a previous failure.
No apport report written because MaxReports is reached already
ng unconfigured
dpkg: dependency problems prevent configuration of cups-ppdc:
 cups-ppdc depends on libcups2 (>= 1.4.0); however:
 cups-ppdc depends on libcupsppdc1 (>= 1.4.0); however:
  Package libcupsppdc1 is not configured yet.
dpkg: error processing cups-ppdc (--configure):
dpkg: dependency problems prevent configuration of cups:
 cups depends on libcups2 (>= 1.5.0); however:
 cups depends on libcupscgi1 (>= 1.4.2); however:
  Package libcupscgi1 is not configured yet.
 cups depends on libcupsmime1 (>= 1.5.0); however:
      Package libcupsmime1 is not configured yet.
 cups depends on libcupsppdc1 (>= 1.4.0); however:
 cups depends on cups-client (>= 1.5.3-0ubuntu4); however:
  Package cups-client is not configured yet.
 cups depends on cups-ppdc; however:
  Package cups-ppdc is not configured yet.
dpkg: error processing cups (--configure):
dpkg: dependency problems prevent configuration of libcupsdriver1:
 libcupsdriver1 depends on libcups2 (>= 1.4.0); however:
dpkg: error processing libcupsdriver1 (--configure):
dpkg: dependency problems prevent configuration of openjdk-7-jre-headless:
 openjdk-7-jre-headless depends on libcups2 (>= 1.4.0); however:
dpkg: error processing openjdk-7-jre-headless (--configure):
dpkg: dependency problems prevent configuration of openjdk-7-jre:
 openjdk-7-jre depends on openjdk-7-jre-headless (= 7u7-2.3.2-1ubuntu0.12.04.1);         however:
  Package openjdk-7-jre-headless is not configured yet.
 openjdk-7-jre depends on libcups2 (>= 1.4.0); however:
dpkg: error processing openjdk-7-jre (--configure):
dpkg: dependency problems prevent configuration of cups-bsd:
 cups-bsd depends on libcups2 (>= 1.4.0); however:
 cups-bsd depends on cups-client (= 1.5.3-0ubuntu4); however:
dpkg: error processing cups-bsd (--configure):
dpkg: dependency problems prevent configuration of icedtea-7-jre-jamvm:
 icedtea-7-jre-jamvm depends on openjdk-7-jre-headless (= 7u7-2.3.2-1ubuntu0.12.04.1); however:
dpkg: error processing icedtea-7-jre-jamvm (--configure):
dpkg: dependency problems prevent configuration of openjdk-7-jre-lib:
 openjdk-7-jre-lib depends on openjdk-7-jre-headless (>= 7~b130~pre0); however:
dpkg: error processing openjdk-7-jre-lib (--configure):
 libcups2
 libcups2:i386
 libcupsmime1
 libcupscgi1
 libcupsppdc1
 cups-client
 cups-ppdc
 cups
 libcupsdriver1
 openjdk-7-jre
 cups-bsd
 icedtea-7-jre-jamvm
 openjdk-7-jre-lib
I've done "apt-get update" and "apt-get upgrade" and this hasn't fixed the problem:
$ sudo apt-get upgrade
You might want to run 'apt-get -f install' to correct these.
 libcups2 : Breaks: libcups2:i386 (!= 1.5.3-0ubuntu3) but 1.5.3-0ubuntu4 is installed
 libcups2:i386 : Breaks: libcups2 (!= 1.5.3-0ubuntu4) but 1.5.3-0ubuntu3 is installed
E: Unmet dependencies. Try using -f.
parsley72
  • 382
http://www.iasptk.com/ubuntu-fix-broken-package-best-solution
After trying
sudo dpkg --configure -a
and
sudo apt-get install -f
the problem of a broken package still exist the solution is to edit the dpkg status file manually.
`sudo nano /var/lib/dpkg/status`    (you can use vi or gedit instead of nano)
Locate the corrupt package, and remove the whole block of information about it and save the file.
ptheo
  • 1,686
