I got this error message after the most recent upgrade:
dpkg: dependency problems prevent configuration of initramfs-tools:
 initramfs-tools depends on initramfs-tools-bin (<< 0.99ubuntu13.2.1~); however:
  Version of initramfs-tools-bin on system is 0.103ubuntu0.2.
 klibc-utils (2.0.1-1ubuntu2) breaks initramfs-tools (<< 0.103) and is installed.
  Version of initramfs-tools to be configured is 0.99ubuntu13.2.
dpkg: error processing initramfs-tools (--configure):
 dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of plymouth:
 plymouth depends on initramfs-tools; however:
  Package initramfs-tools is not configured yet.
dpkg: error processing plymouth (--configure):
dpkg: dependency problems prevent configuration of mountall:
 mountall depends on plymouth; however:
  Package plymouth is not configured yet.
dpkg: error processing mountall (--configure):
No apport report written because MaxReports is reached already
        dpkg: dependency problems prevent configuration of initscripts:
 initscripts depends on mountall (>= 2.28); however:
  Package mountall is not configured yet.
dpkg: error processing initscripts (--configure):
dpkg: dependency problems prevent configuration of upstart:
 upstart depends on initscripts; however:
  Package initscripts is not configured yet.
 upstart depends on mountall; however:
dpkg: error processing upstart (--configure):
dpkg: dependency problems prevent configuration of passwd:
 passwd depends on upstart-job; however:
  Package upstart-job is not installed.
  Package upstart which provides upstart-job is not configured yet.
dpkg: error processing passwd (--configure):
 initramfs-tools
 plymouth
 mountall
 initscripts
 upstart
 passwd
fosslinux
  • 3,881
Open terminal and execute these commands:
sudo apt-get autoremove
sudo apt-get --purge remove && sudo apt-get autoclean
sudo apt-get -f install
sudo dpkg-reconfigure -a
Last command would take some time depends upon packages installed in your system. So please be patient. If you don't have any broken/residual packages it would execute silently without any message.
sudo apt-get update
sudo apt-get upgrade && sudo apt-get dist-upgrade
sudo dpkg --configure -a
sudo update-initramfs -u
Then restart your system.
fosslinux
  • 3,881
Saurav Kumar
  • 15,174
My one-liner to remove old kernels (this also frees up disk space):
dpkg --list | grep linux-image | awk '{ print $2 }' | sort -V | sed -n '/'`uname -r`'/q;p' | xargs sudo apt-get -y purge
Explanation (remember, | uses the output of the previous command as the input to the next)
  • dpkg --list lists all installed packages
  • grep linux-image looks for the installed linux images
  • awk '{ print $2 }' just outputs the 2nd column (which is the package name)
  • sort -V puts the items in order by version number
  • sed -n '/'`uname -r`'/q;p' prints the lines before the current kernel
  • xargs sudo apt-get -y purge purges the found kernels
Unwinding the sed invocation:
  • -n tells sed to be quiet
  • `uname -r` outputs the current installed kernel release - we include it in backticks so that the output is includes as part of the command (you might also see this as $(uname -r)
  • /something/q says stop when you match 'something' (in this case, something is output of uname -r) - the / surround a regular expression
  • p is print
  • the ; is the command separtor, so /something/q;p says quit when you match something, else print
altogether, sed -n '/'`uname -r`'/q;p' is print the lines until it matches with the current kernel name.
If you're paranoid (like me), you can make the last part xargs echo sudo apt-get -y purge so that the command to purge the old kernels is printed, then you can check that nothing unexpected is included before you run it.
Modified version to remove headers:
dpkg --list | grep 'linux-image' | awk '{ print $2 }' | sort -V | sed -n '/'"$(uname -r | sed "s/\([0-9.-]*\)-\([^0-9]\+\)/\1/")"'/q;p' | xargs sudo apt-get -y purge
dpkg --list | grep 'linux-headers' | awk '{ print $2 }' | sort -V | sed -n '/'"$(uname -r | sed "s/\([0-9.-]*\)-\([^0-9]\+\)/\1/")"'/q;p' | xargs sudo apt-get -y purge
Note: the sed invocation is modified. "$(uname -r | sed "s/\([0-9.-]*\)-\([^0-9]\+\)/\1/")" extracts only the version (e.g. "3.2.0-44") , without "-generic" or similar from uname -r
All-in-one version to remove images and headers (combines the two versions above):
echo $(dpkg --list | grep linux-image | awk '{ print $2 }' | sort -V | sed -n '/'`uname -r`'/q;p') $(dpkg --list | grep linux-headers | awk '{ print $2 }' | sort -V | sed -n '/'"$(uname -r | sed "s/\([0-9.-]*\)-\([^0-9]\+\)/\1/")"'/q;p') | xargs sudo apt-get -y purge
fosslinux
  • 3,881
arukaen
  • 87
