I have trouble install packages with apt-get. I get the following error:
 trying to overwrite '/usr/bin/soffice', which is also in package openoffice-debian-menus 4.1-9764
rmdir: failed to remove ‘/var/lib/libreoffice/share/prereg/’: No such file or directory
rmdir: failed to remove ‘/var/lib/libreoffice/share/’: No such file or directory
rmdir: failed to remove ‘/var/lib/libreoffice/program/’: No such file or directory
rmdir: failed to remove ‘/var/lib/libreoffice’: No such file or directory
Processing triggers for shared-mime-info (1.2-0ubuntu3) ...
Processing triggers for man-db (2.6.7.1-1) ...
Processing triggers for gnome-icon-theme (3.10.0-0ubuntu2) ...
Processing triggers for hicolor-icon-theme (0.13-1) ...
Processing triggers for gnome-menus (3.10.1-0ubuntu2) ...
Processing triggers for desktop-file-utils (0.22-1ubuntu1) ...
Processing triggers for bamfdaemon (0.5.1+14.04.20140409-0ubuntu1) ...
Rebuilding /usr/share/applications/bamf-2.index...
Processing triggers for mime-support (3.54ubuntu1) ...
 /var/cache/apt/archives/libreoffice-common_1%3a4.2.6.3-0ubuntu1_all.deb
For every package I'm trying to install.
I've tried following the discussions in: http://ubuntuforums.org/showthread.php?t=1889732 error installing libreoffice 4-0
but had no success.
can anyone help?
ok thanks. I solved by running:
sudo apt-get remove --purge libreoffice-core libreoffice-common python3-uno libreoffice-*
for some reason removing each package separately has failed but in the same command - it worked
The OP solved the problem himself in the question:
Seth
  • 59,332
