I had installed LibreOffice 4.0.4, then I added PPA LibreOffice 4-1, and installed new version (LO 4-1). However, there is menu delay problem, so I decided to remove 4-1 and install 4-0 again...
sudo apt-get remove --purge libreoffice*
sudo apt-get clean
sudo apt-get autoremove
LO 4-1 was removed, but now I cannot install 4-0.
This is error message:
distribution that some required packages have not yet been created or
been moved out of Incoming. The following information may help to
resolve the situation:
The following packages have unmet dependencies:  libreoffice :
Depends: libreoffice-base but it is not going to be installed
                Depends: libreoffice-calc but it is not going to be installed
                Depends: libreoffice-core (= 1:4.0.2-0ubuntu1) but it is not going to be installed
                Depends: libreoffice-draw but it is not going to be installed
                Depends: libreoffice-filter-mobiledev but it is not going to be installed
                Depends: libreoffice-impress but it is not going to be installed
                Depends: libreoffice-math but it is not going to be installed
                Depends: libreoffice-report-builder-bin but it is not going to be installed
                Depends: libreoffice-writer but it is not going to be installed
                Depends: libreoffice-java-common (>= 1:4.0.2~) but it is not going to be installed
                Depends: python3.3-uno but it is not installable or
                         python3-uno (>= 4.0~) but it is not going to be installed or
                         python-uno but it is not going to be installed
                Recommends: libreoffice-gnome but it is not going to be installed or
                            libreoffice-kde but it is not going to be installed E: Unable to correct problems, you have held broken packages.
Mitch
  • 109,787
lilicus
  • 183
I had to install "ure" from Synaptic Package Manager but in options I had to select to "force previous version", ie. 4.0.2.... after that, I was able to install Libre Office...
lilicus
  • 183
To install LibreOffice 4 you will need to completely remove all previous versions. Run:
sudo apt-get remove --purge libreoffice-core libreoffice-common
sudo apt-get autoremove --purge
Then install by:-
sudo add-apt-repository ppa:libreoffice/libreoffice-4-0
sudo apt-get update
sudo apt-get dist-upgrade
or get the more details you can see this Q.: How do I install LibreOffice 4?
