26
I am trying to save power by switching desktops to suspend mode when they are inactive. But many desktops are also accessed via SSH by their owners. There is a wakeonlan solution deployed to enable owners to switch on the machine, but the problem is that machines will auto-suspend again in 10 minutes, even though the SSH connection is on.
What I am trying to do is to include the active SSH sessions in the "activity" definitions.
The question is can it be done via setting a polkit rule? Can it be done via putting a script that runs before the actual suspend, and aborts it if SSH sessions are found? I need a clean legit way of doing this. If not that, then hacky ways are also welcome.
Current naive hacky solution: edit /usr/sbin/pm-suspend:
#check for SSH sessions, and prevent suspending:
if [ "$(who | grep -cv "(:")" -gt 0 ]; then
    echo "SSH session(s) are on. Not suspending."
    exit 1
fi
This serves the purpose. But I don't know when an update will overwrite the file /usr/sbin/pm-suspend. I also don't know how this will work with other suspend implementations like tuxonice.
Bhavin Doshi
  • 2,496
8 Answers8
25
Until Ubuntu 14.10 (Upstart-based)
Have a look at pm-action(8) and search for /etc/pm/sleep.d in section “FILES”. If one of these scripts returns with a non-zero exit status, suspension is prevented.
Updated instructions for clarity:
  1. So create a file /etc/pm/sleep.d/05_ssh_keepawake.
  2. Put a shebang (#!/bin/sh) and the code mentioned in the question in this file.
  3. Set execute permissions on it:
    chmod +x /etc/pm/sleep.d/05_ssh_keepawake
Since Ubuntu 15.04 (systemd-based)
systemd doesn’t use pm-utils to manage its power state hooks but has its own infrastructure to the same end. Sleep inhibitor checkers are no longer executed on sleep but must be set by the action that inhibits sleep (see 1).
As such you’d have to add commands to the SSH session log-in and log-out that registers a sleep inhibitor with systemd (e. g. via systemd-inhibit(1)) and later releases the inhibitor. If somebody knows how to hook into SSH log-in and log-out, I’d welcome a comment or edit so that we could work out the relevant steps and commands.
The following section is work in progress – Only use it when you know what you’re doing!
You might be able to write a systemd unit /etc/systemd/system/ssh-inhibit-sleep.service that makes itself a dependency of sleep.target using the RequiredBy option. If your new unit fails (with a non-zero exit status from its invoked process), it will make sleep.target and thus the subsequent sleep action.
[Unit]
Description=Check for running SSH sessions and, if any, inhibit sleep
Before=sleep.target
[Service] Type=oneshot ExecStart=/bin/sh -c '! who | grep -qv "(:0)"'
[Install] RequiredBy=sleep.target
As always you need to activate systemd units for them to take effect:
sudo systemctl enable ssh-inhibit-sleep.service
For more info see systemd.unit(5) and systemd.service(5).
David Foerster
  • 36,890
  • 56
  • 97
  • 151
Combining two related answers (here and here), here's an /etc/pam_session.sh that does the trick on Ubuntu 19.10 (at least):
#!/bin/sh
# This script runs when an ssh session opens/closes, and masks/unmasks
# systemd sleep and hibernate targets, respectively.
# Inspired by: https://unix.stackexchange.com/a/136552/84197 and
#              https://askubuntu.com/a/954943/388360
num_ssh=$(netstat -nt | awk '$4 ~ /:22$/ && $6 == "ESTABLISHED"' | wc -l)
case "$PAM_TYPE" in open_session) if [ "${num_ssh}" -gt 1 ]; then exit fi command=mask ;;
close_session)
    if [ "${num_ssh}" -ne 0 ]; then
        exit
    fi
    command=unmask
    exit
esac
logger "${command}ing sleep and suspend targets (num_ssh=${num_ssh})" sudo systemctl ${command} sleep.target suspend.target
Make sure to add the line:
session     optional    pam_exec.so quiet /etc/pam_session.sh
to /etc/pam.d/sshd in the session section, and make the /etc/pam_session.sh script executable:
chmod +x /etc/pam_session.sh
Note that the /etc/pam_session.sh script appears to run as the the user logging in or out, so that user requires sudo access to mask/unmask systemd targets.
claymation
  • 191
In modern systemd systems, you can also use the ssh.socket service together with systemd-inhibit. Instead of running the usual ssh.service standalone, you can let systemd manage the incoming connections. Each open session now gets handled by ssh.socket which creates the instance units based on ssh@.service, so it is just a matter creating a service that binds directly to that. This has the added benefit of tracking and logging each ssh connection with systemd. We can then use this identifier to provide more useful information when blocking sleep. This method also prevents degrading systemd with a failing unit like some other examples.
First you need to check to make sure to enable ssh.socket if you are not already using it.
systemctl is-active ssh.socket
Should say active otherwise you will need to enable it:
sudo systemctl disable ssh
sudo systemctl stop ssh
sudo systemctl enable ssh.socket
sudo systemctl start ssh.socket
Then you just need is to create /etc/systemd/system/ssh-no-sleep@.service with
[Unit]
Description=ssh no sleep
BindsTo=ssh@%i.service
[Service] ExecStart=/usr/bin/systemd-inhibit --mode block --what sleep --who "ssh session "%I --why "session still active" /usr/bin/sleep infinity
[Install] WantedBy=ssh@.service
And enable it with:
sudo systemctl enable ssh-no-sleep@
In order for the ssh@.service alias (represented with the @) to be triggered you have to make sure your ssh.socket service has the [Socket] setting Accept=yes, otherwise the no sleep service will never trigger for each new connection. You can test your systemd default settings by running:
sudo systemctl show --no-pager --property Accept ssh.socket
If this returns no, you will need to override it to yes by creating a conf file /etc/systemd/system/ssh.socket.d/accept.conf with:
[Socket]
Accept=yes
If your system is missing ssh@.service or ssh.socket, here is the one from Debian Bullseye as an example that you can work off of:
/etc/systemd/system/ssh@.service
[Unit]
Description=OpenBSD Secure Shell server per-connection daemon
Documentation=man:sshd(8) man:sshd_config(5)
After=auditd.service
[Service] EnvironmentFile=-/etc/default/ssh ExecStart=-/usr/sbin/sshd -i $SSHD_OPTS StandardInput=socket RuntimeDirectory=sshd RuntimeDirectoryMode=0755
[Unit]
Description=OpenBSD Secure Shell server socket
Before=sockets.target
ConditionPathExists=!/etc/ssh/sshd_not_to_be_run
[Socket] ListenStream=22 Accept=no
[Install] WantedBy=sockets.target
After saving this, running systemctl daemon-reload and systemctl restart ssh.socket , you can re-run the prior show command to confirm Accept=yes
Now when someone tries to suspend, they will get a useful message of all the blocking ssh sessions
sudo systemctl suspend
Will then return something like:
Operation inhibited by "ssh session 1/127.0.0.1:22/127.0.0.1:12345" (PID 12345 "systemd-inhibit", user root), reason is "session still active".
Operation inhibited by "ssh session 2/2001:db8:1::1:22/2001:db8:2::1:12345" (PID 54321 "systemd-inhibit", user root), reason is "session still active".
Please retry operation after closing inhibitors and logging out other users.
Alternatively, ignore inhibitors and users with 'systemctl suspend -i'.
Added benefit of ssh.socket is that you can also use:
systemctl status ssh.socket
Which returns active users and system stats:
* ssh.socket - OpenBSD Secure Shell server socket
     Loaded: loaded (/lib/systemd/system/ssh.socket; enabled; vendor preset: enabled)
     Active: active (listening) since Mon 2021-12-20 14:46:05 EST; 1h 6min ago
   Triggers: * ssh@2-2001:db8:1::1:22-2001:db8:2::1:12345.service
             * ssh@1-127.0.0.1:22-127.0.0.1:12345.service
     Listen: [::]:22 (Stream)
   Accepted: 2; Connected: 2;
      Tasks: 0 (limit: 18775)
     Memory: 16.0K
        CPU: 2ms
     CGroup: /system.slice/ssh.socket
Jude
  • 161
If you want a one-off solution, for an individual ssh session, the following works well on systemd-based systems:
systemd-inhibit --what=idle $SHELL
The default value of the --what argument is idle:sleep:shutdown and the last two states require root privileges. By specifying only idle the command can be run by any user.
Update: This doesn't always work. I think it depends on what desktop environment you're using. Gnome Shell, for example, seems to be doing its own idle detection and requests sleep directly.
With Gnome, you can do this instead:
gnome-session-inhibit --inhibit suspend:idle $SHELL
not sure if this will solve what you want, but it did for my case.
After login via ssh, use:
    DISPLAY=:0 caffeinate bash
(or any other shell installed instead of bash)
It will prevent sleeping while you are connected to the machine via ssh. You can take a look at the caffeinate manpage.
My own solution involves adding the following to .bashrc/.zshrc/…
if [ "$SSH_CLIENT" ] &&
     ! pstree -ps $$ |
       grep -q -- '-systemd-inhibit(' >/dev/null; then
echo "Inhibit automatic standby" exec /usr/bin/systemd-inhibit
--what=idle --why='Interactive SSH Session' --
"$SHELL" "$@"
fi
It works by routing/wrapping the shell on the remote through/using systemd-inhibit (and also making sure that there is only a single systemd-inhibit in the call chain, so it is not called again in case you enter a sub-shell).
Obviously, it only applies to SSH sessions with a shell.
phk
  • 401
  • 16
A simpler method would be adding the following python script to the root crontab (echo "*/1 * * * * python3 /path/to/inhibit.py" | sudo tee -a /etc/crontab) to check if an active SSH session is present every minute and inhibit sleep:
import subprocess, time, dbus  # noqa: E401
from filelock import FileLock
def run_command(command): result = subprocess.run( command, stdout=subprocess.PIPE, stderr=subprocess.PIPE, shell=True, ) return result.stdout.decode("utf-8")
INHIBIT_FD = None with FileLock("/tmp/inhibit_ssh.lock", 0): while True: # Run lsof command and count the number of established connections containing "code". # Counts vscode remote-ssh server instances. You may not require this. code_conns = run_command("lsof -i | grep 'code' | grep 'ESTABLISHED'").count("\n") # Run who command and count the number of active sessions (pts) ssh_conns = run_command("who | grep 'pts'").count("\n") total_conns = code_conns + ssh_conns
    if total_conns > 0:
        if not INHIBIT_FD:
            manager = dbus.Interface(
                dbus.SystemBus().get_object(
                    "org.freedesktop.login1", "/org/freedesktop/login1"
                "org.freedesktop.login1.Manager",
            res = manager.Inhibit("sleep", "sshInhibit", "SSH Active", "block")
            INHIBIT_FD = res.take()
            print("FD:", INHIBIT_FD)
        print("SSH Active")
        time.sleep(60)
    else:
        break
Be awared that is hibernate in lieu of suspend in my case. Please customize to yours!
Firstly, create a configuration file that placed at /etc/configure_sleep.sh (or anywhere that you like). This script aims to enable/disable the sleep based on your configuration (refer to Prevent sleep/suspend when not logged in to a specific account).
#!/bin/sh
# This script is to configure the sleep entries
TIMEOUT=60 IS_LOGIN_SCREEN=$(pgrep -u gdm gnome-session)
command=$1
if [ "${command}" = "enable" ] ; then sudo -Hu gdm dbus-launch dconf write /org/gnome/settings-daemon/plugins/power/sleep-inactive-ac-timeout ${TIMEOUT} sudo -Hu gdm dbus-launch dconf write /org/gnome/settings-daemon/plugins/power/sleep-inactive-ac-type "'hibernate'" else sudo -Hu gdm dbus-launch dconf write /org/gnome/settings-daemon/plugins/power/sleep-inactive-ac-timeout 0 sudo -Hu gdm dbus-launch dconf write /org/gnome/settings-daemon/plugins/power/sleep-inactive-ac-type "'nothing'" fi echo "I'm here" if [ -z "${IS_LOGIN_SCREEN}" ] ; then echo "In user's screen." else echo "This is login screen. Gnome binary will be forcedly reloaded." sudo killall -3 gnome-session-binary fi
Secondly, rely on Prevent machine from sleeping when SSH connections are on, but, instead of masking and unmasking the sleep targets that get an annoying problem with the broadcasting keeps announce. The first script will be launched appropriately. Put this script in /etc/pam_session.sh.
#!/bin/sh
# and changes the gnome settings, respectively.
# Inspired by: https://askubuntu.com/questions/521620/
SCRIPT_PATH="/etc/pam_session.sh" DBUS=unix:path=/run/user/1000/bus
close_session)
        exit
    fi
    command=unmask
    exit
esac
logger "${SCRIPT_PATH}: ${command}ing sleep and suspend targets (num_ssh=${num_ssh})"
if [ ${command} = unmask ] ; then /etc/configure-sleep.sh "enable" logger "${SCRIPT_PATH}: Re-enable Auto Hibernate" else /etc/configure-sleep.sh "disable" logger "${SCRIPT_PATH}: Disable Auto Hibernate" fi
Add the script into the ssh service pam and don’t forget to make these scripts executable.
Add this line to /etc/pam.d/sshd under the session session.
And make them executable.
chmod +x /etc/configure-sleep.sh
Everything seems to fine until now. Perhaps, if you turn off the computer while ssh sessions is alive (auto sleep is off), the auto sleep will not be functional in the next power cycle. My solution delegates a service to self-enable the module.
Create a file named 99-defaultHibernate.service and placed in /etc/systemd/system/.
[Unit]
Description=Setup default hibernaten
[Service] Type=oneshot ExecStartPre=/bin/sleep 10 ExecStart=/etc/configure-sleep.sh enable
[Install] WantedBy=basic.target
Make the service affects by the following procedures.
sudo systemctl daemon-reload
sudo systemctl enable 99-defaultHibernate.service
sudo systemctl start 99-defaultHibernate.service
Please not that this approach adopts the kill of gnome binary session. It might cause potential risks or unforeseen defects.
P/s: Any indication is always welcome!
