25
We have a shared office desktop running Ubuntu 18.04 where several jobs (via ssh and screen) often run for weeks on multiple accounts. When logged into an account, sleep/suspend is deactivated through:
  1. Power settings in main System Setting
  2. Using gnome-tweak-tool, setting "Suspend when laptop lid is closed" to off.
This works fine as long as a user with these power settings is always directly logged into the machine (i.e., physically, not via ssh).
The problem is when no user is currently logged in directly i.e., when the machine is at the main login screen (like on boot up). There does not appear to be a way to set sleep/suspend settings when not logged into a specific account. So, if the machine remains on this screen, it eventually sleeps, suspending all the running jobs.
As I mentioned, things work fine as long as some user is logged in. However, this has been viewed as a security risk. So we'd like to find a better system-wide solution.
I should mention that we have another office desktop running Ubuntu 16.04 which does not have this problem.
josephwb
  • 348
When no user is signed on
When no user is signed on the power settings come from psuedo-user ID gdm. The following controls for GDM auto-suspend come from: ArchLinux GDM
GDM auto-suspend (GNOME 3.28)
GDM uses a separate dconf database to control power management. You can make GDM behave the same way as user sessions by copying the user settings to GDM's dconf database.
$ IFS=$'\n'; for x in $(sudo -u username gsettings list-recursively org.gnome.settings-daemon.plugins.power); do eval "sudo -u gdm dbus-launch gsettings set $x"; done; unset IFS
where username is your user's name.
Or to simply disable auto-suspend (also run the command with ac replaced with battery to also disable it while running on battery):
$ sudo -u gdm dbus-launch gsettings set org.gnome.settings-daemon.plugins.power sleep-inactive-ac-type 'nothing'
edit file /etc/systemd/logind.conf
there you can find the line:
#HandleLidSwitch=suspend
change it to:
HandleLidSwitch=ignore
now your login screen ignores your lid switch also.
There is a good ubuntu manual page of logind.conf:
http://manpages.ubuntu.com/manpages/cosmic/man5/logind.conf.5.html
To disable suspend via policykit (systemwide setting) follow instructions on:
https://sites.google.com/site/easytipsforlinux/disable-hibernate-and-suspend
You have to change the settings of the user gdm.
As root execute
sudo -Hu gdm dbus-launch dconf write /org/gnome/settings-daemon/plugins/power/sleep-inactive-ac-timeout 3600
sudo -Hu gdm dbus-launch dconf write /org/gnome/settings-daemon/plugins/power/sleep-inactive-ac-type "'nothing'"
sudo -Hu gdm dbus-launch dconf write /org/gnome/settings-daemon/plugins/power/sleep-inactive-battery-timeout 1800
sudo -Hu gdm dbus-launch dconf write /org/gnome/settings-daemon/plugins/power/sleep-inactive-battery-type "'nothing'"
(Probably you don't need the two lines with the timeout.)
Check the settings with
sudo -u gdm dconf dump /
wdp
  • 179
-3
If you are using UBUNTU 18.04 you can use an indicator named
Caffeine Indicator
you can get it from software store and install it.
Activate it so that it can Manually control the desktop’s idle state
Hope so it will help..
