I couldnt get MythTV system events to work. Tried my best playing with permissions all in vain. Here is a my current working code. Replace the database variables with your settings. Save it as say /etc/cron.daily/idle_htpc.py If any of the step fails program will quit. Just sudo crontab -e this for every 5-59/15 * * * * /etc/cron.daily/idle_htpc.py /var/log/htpc_out 2> /var/log/htpc_err 15 minutes
Step 1: Look if there are any SSH connections
Step 2: Check if live or recorded video being played at the moment. If not sleep for 5 minutes
Step 3: Check once again if live or recorded video being played at the moment
Step 4: Check if there was a live stream within the last 5minutes just in case there was a sub-5 minute stream while the script was sleeping in Step 2. However if there was a recorded playback there is no means to detect here.
Step 5: Check the next upcoming recording and if there is one and it is >5minutes from now set ACPI wakeup 3 minutes before start time and shutdown or else clear ACPI wakeup and shutdown.
Hope this helps someone.
#!/usr/bin/python3
import pymysql
import pymysql.cursors
from datetime import timedelta,datetime
import subprocess
import time
import sys
print ( datetime.now().strftime("%Y-%m-%d %H:%M:%S"), file=sys.stdout)
def check_Logins():
#Returns the number of SSH connections
#result= subprocess.run('who | grep -cv "(:"', stdout=subprocess.PIPE, shell=True)
result= subprocess.run("netstat -n |grep tcp |grep ':22' |wc -l", stdout=subprocess.PIPE, shell=True)
print ('Logins:'+result.stdout.decode('UTF-8'), file=sys.stdout)
return (int(result.stdout.decode('UTF-8')))
def check_if_InUse():
#Checks if a live stream or a previosuly recorded program is being served at this moment. If yes, non zero value is returned
InUse=1
connection = pymysql.connect(host=$host,
user=$username,
password=$password,
db=$db,
charset='utf8mb4',
cursorclass=pymysql.cursors.DictCursor)
try:
with connection.cursor() as cursor:
# Read a single record
sql = "select count(*) from inuseprograms where recusage !='jobqueue' and recusage !='flagger'"
cursor.execute(sql)
result = cursor.fetchone()
InUse = result["count(*)"]
finally:
connection.close()
print ("Count: "+str(InUse), file=sys.stdout)
return InUse
def check_live_5min():
#Checks if there were any live streams served in last 5 minutes
RecInUse_5min=1
user=$username,
password=$password,
db=$db,
charset='utf8mb4',
try:
sql = "select max(starttime) from recordedseek"
cursor.execute(sql)
print ('Recent: ', result['max(starttime)'], file=sys.stdout)
print ('Current: ',datetime.utcnow(), file=sys.stdout)
if datetime.utcnow()-result['max(starttime)']>=timedelta(minutes=5):
RecInUse_5min =0
finally:
connection.close()
return RecInUse_5min
def get_next_rec():
#Returns a tuple indicating if there is any scheduled recording if yes, how far into the future
retdata = (True, timedelta(minutes=1))
user=$username,
password=$password,
db=$db,
charset='utf8mb4',
try:
sql = "select MIN(next_record) from record where recordid!=1 and next_record IS NOT NULL;"
cursor.execute(sql)
if result['MIN(next_record)'] is None: #no scheduled recordings
retdata= (False,timedelta(minutes=1))
else:
retdata= (True,result['MIN(next_record)']-datetime.utcnow())
finally:
connection.close()
return retdata
if check_Logins()==0:
print ('First check passed', file=sys.stdout)
if check_if_InUse() == 0:
print ('Second check passed', file=sys.stdout)
time.sleep(5*60)
print ('Third check passed', file=sys.stdout)
if check_live_5min()==0:
print ('Fourth check passed', file=sys.stdout)
(valid,upcoming) = get_next_rec()
# Clear any previously set wakeup time
result = subprocess.run('echo 0 > /sys/class/rtc/rtc0/wakealarm',stdout=subprocess.PIPE,shell=True)
print ('Clear:'+result.stdout.decode('UTF-8'), file=sys.stdout)
if valid is True:
# Generate wakeup time string
upcoming = upcoming - timedelta(minutes=3)
wakeup_string="'+"+str(upcoming.days)+" days + "+str(max([int(upcoming.seconds/60)-3,0]))+" minutes'"
print ('Setting for '+wakeup_string, file=sys.stdout)
wakeup_command="echo `date '+%s' -d " +wakeup_string+ "` > /sys/class/rtc/rtc0/wakealarm"
#Setup wakeup time
result = subprocess.run(wakeup_command,stderr=subprocess.PIPE, shell=True)
print ('Set:'+result.stderr.decode('UTF-8'), file=sys.stdout)
#Check if alarm is set. It should show the unix time stamp
result= subprocess.run('cat /sys/class/rtc/rtc0/wakealarm', stdout=subprocess.PIPE, shell=True)
print ('Check:'+result.stdout.decode('UTF-8'), file=sys.stdout)
print ('Shutting down', file=sys.stdout)
subprocess.Popen(['/sbin/shutdown', '-h', 'now'])
