I am trying to use bluetooth audio speakers, as my integred laptop speakers are so awful... The speaker is a Bose Soundlink mini and works just fine with my smartphone for example.
When I try to use it with my laptop (Ubuntu 14.04), it works ok, until I begin to work. Then sound begins to shutter, with this kind of logs:
Sep  3 17:29:38 franck-ThinkPad-T430s pulseaudio[3673]: [bluetooth] module-bluetooth-device.c: Skipping 30147 us (= 5316 bytes) in audio stream
Sep  3 17:29:38 franck-ThinkPad-T430s pulseaudio[3673]: [bluetooth] module-bluetooth-device.c: Skipping 79152 us (= 13960 bytes) in audio stream
Sep  3 17:29:41 franck-ThinkPad-T430s pulseaudio[3673]: [bluetooth] module-bluetooth-device.c: Skipping 3467134 us (= 611600 bytes) in audio stream
This happens as soon as I type on the keyboard (be it in libreoffice or in a terminal, or whatever). The keyboard is not a bluetooth keyboard, in case you ask.
When using internal speakers, I don't suffer the same problem.
So, is there a trick to give the full bluetooth audio stack higher priority and get a consistent audio plackback ? (bluetoothd ? pulseaudio ? low level interupts ? ???)
UPDATE: my bluetooth controller is attached to (internal) USB.
$ lsusb -v -s 001:004
Bus 001 Device 004: ID 0a5c:21e6 Broadcom Corp. BCM20702 Bluetooth 4.0 [ThinkPad]
alci
  • 5,979
I finally found a solution (in fact several one):
  1. Add threadirqs to my kernel params
  2. was better, but this was not enough, I also had to install rtirq-init (you should check if you kernel supports this, see https://unix.stackexchange.com/a/55001/61603)
I then had an (almost) perfect bt sound playback.
Another option seems to use linux-lowlatency kernel. I still have to test this, but it should work. What is unclear is the drackbacks (power consumption ?).
WiR3D
  • 7,340
alci
  • 5,979
