since I upgraded from 12.04 to 14.04 I can't boot in any other mode than through recovery mode. If I don't, the mouse hardly works then freezes, same for keyboard. Still, after using the recovery mode my PC works but operating any function is very slow and it sometimes freezes. I had a lot of freezing incidents when still using the 12.04, so when the problem I describe above came up after the upgrade, I decided to wipe my hard drive clean with DBAN to make sure nothing would be carried over and then downloaded 14.04 from a USB drive... with the same results. The dpkg option on the recovery menu highlighted a series of errors that I'll be happy to post if anyone asks. I also got a few pop-ups early after the download warning me about problems with programs such as compiz, webapp-container or aptdaemon, among other glitches. If you could let me know how I should handle this, I'll be very grateful indeed! Fred
Asked
Active
Viewed 97 times
Some quick hints:
- To check the memory, boot from the install CD and select memtest (see here for details)
- To check the disks you can use
Disks, the Gnome utility. More about all this in this article.
Hope this helps...
Pyrophorus
- 514
