Provided that your hardware support 64-bits, which does:
CPU op-mode(s): 32-bit, 64-bit
and the package was prepared to use multiarch, which is also true:
dpkg -I viber.deb
new debian package, version 2.0. <--- here
size 57046082 bytes: control archive=8024 bytes.
0 bytes, 0 lines 0
1210 bytes, 29 lines control
9475 bytes, 33 lines * copyright
7404 bytes, 85 lines md5sums
39 bytes, 2 lines * postinst #!/bin/bash
800 bytes, 35 lines * preinst #!/bin/bash
500 bytes, 24 lines * prerm #!/bin/bash
Package: viber
Version: 4.2.2.6
Section: non-free/net
Priority: extra
Architecture: amd64 <---- and here
you could just install the necessary 64-bit libraries and binaries which are dependency of the package (which is none, more about that later) that you need to run the application, with virtual zero performance impact. In my case, I just installed the package just fine:
$ sudo dpkg --add-architecture amd64
## adding 64-bits architecture package, in my system I didn't need to
## but it's likely you have
$ sudo apt-get update # this downloads the package list for amd64 arch
$ sudo dpkg -i viber.deb
Selecting previously unselected package viber.
(Reading database ... 268703 files and directories currently installed.)
Preparing to unpack viber.deb ...
Unpacking viber (4.2.2.6) ...
Setting up viber (4.2.2.6) ...
Processing triggers for hicolor-icon-theme (0.13-1) ...
Processing triggers for gnome-menus (3.13.3-1) ...
Processing triggers for mime-support (3.56) ...
Processing triggers for desktop-file-utils (0.22-1) ...
And then started running into problems...
The package managers decided that they should not list any dependency for their package,
Installed-Size: 141336
Conflicts: Viber (<< 4.2.2.6)
Replaces: Viber (<< 4.2.2.6)
Maintainer: Viber Media Inc <support@viber.com>
which they actually need:
ldd /opt/viber/Viber | grep 'not found'
libXcomposite.so.1 => not found
libxslt.so.1 => not found
libxml2.so.2 => not found
libgstreamer-0.10.so.0 => not found
libgstapp-0.10.so.0 => not found
libgstbase-0.10.so.0 => not found
libgstinterfaces-0.10.so.0 => not found
libgstpbutils-0.10.so.0 => not found
libgstvideo-0.10.so.0 => not found
libsqlite3.so.0 => not found
so you must find and install the libraries missing manually! This is easy if you know the correct tools. apt-file comes handy here, also http://packages.ubuntu.com functionality "Search the contents of packages" comes fine also. But I went ahead and searched for them:
These files are already installed in my system, you only need to copy the package name, the one before the colon that ends with amd64. You should copy the package names as they are:
dpkg -S $(ldd /opt/viber/Viber | awk '{print $3}' | grep -vP 'not|viber')
libc6:amd64: /lib/x86_64-linux-gnu/libpthread.so.0
libc6:amd64: /lib/x86_64-linux-gnu/libdl.so.2
libc6:amd64: /lib/x86_64-linux-gnu/librt.so.1
libstdc++6:amd64: /usr/lib/x86_64-linux-gnu/libstdc++.so.6
libc6:amd64: /lib/x86_64-linux-gnu/libm.so.6
libgcc1:amd64: /lib/x86_64-linux-gnu/libgcc_s.so.1
libc6:amd64: /lib/x86_64-linux-gnu/libc.so.6
libx11-6:amd64: /usr/lib/x86_64-linux-gnu/libX11.so.6
libxext6:amd64: /usr/lib/x86_64-linux-gnu/libXext.so.6
zlib1g:amd64: /lib/x86_64-linux-gnu/libz.so.1
libgl1-mesa-glx:amd64: /usr/lib/x86_64-linux-gnu/libGL.so.1
libxrender1:amd64: /usr/lib/x86_64-linux-gnu/libXrender.so.1
libglib2.0-0:amd64: /lib/x86_64-linux-gnu/libglib-2.0.so.0
libglib2.0-0:amd64: /usr/lib/x86_64-linux-gnu/libgobject-2.0.so.0
libxcb1:amd64: /usr/lib/x86_64-linux-gnu/libxcb.so.1
libglapi-mesa:amd64: /usr/lib/x86_64-linux-gnu/libglapi.so.0
libxdamage1:amd64: /usr/lib/x86_64-linux-gnu/libXdamage.so.1
libxfixes3:amd64: /usr/lib/x86_64-linux-gnu/libXfixes.so.3
libx11-xcb1:amd64: /usr/lib/x86_64-linux-gnu/libX11-xcb.so.1
libxcb-glx0:amd64: /usr/lib/x86_64-linux-gnu/libxcb-glx.so.0
libxcb-dri2-0:amd64: /usr/lib/x86_64-linux-gnu/libxcb-dri2.so.0
libxcb-dri3-0:amd64: /usr/lib/x86_64-linux-gnu/libxcb-dri3.so.0
libxcb-present0:amd64: /usr/lib/x86_64-linux-gnu/libxcb-present.so.0
libxcb-sync1:amd64: /usr/lib/x86_64-linux-gnu/libxcb-sync.so.1
libxshmfence1:amd64: /usr/lib/x86_64-linux-gnu/libxshmfence.so.1
libxxf86vm1:amd64: /usr/lib/x86_64-linux-gnu/libXxf86vm.so.1
libdrm2:amd64: /usr/lib/x86_64-linux-gnu/libdrm.so.2
libpcre3:amd64: /lib/x86_64-linux-gnu/libpcre.so.3
libffi6:amd64: /usr/lib/x86_64-linux-gnu/libffi.so.6
libxau6:amd64: /usr/lib/x86_64-linux-gnu/libXau.so.6
libxdmcp6:amd64: /usr/lib/x86_64-linux-gnu/libXdmcp.so.6
These I didn't had them installed, which I obtained using ldd /opt/viber/Viber | grep 'not found' | awk '{printf "%s$\n", $1}' | apt-file search -x -a amd64 -f - | sed 's/\:/:amd64:/':
$ ldd /opt/viber/Viber | grep 'not found' | awk '{printf "%s$\n", $1}' | apt-file search -x -a amd64 -f - | sed 's/\:/:amd64:/'
libgstreamer-plugins-base0.10-0:amd64: /usr/lib/x86_64-linux-gnu/libgstapp-0.10.so.0
libgstreamer-plugins-base0.10-0:amd64: /usr/lib/x86_64-linux-gnu/libgstinterfaces-0.10.so.0
libgstreamer-plugins-base0.10-0:amd64: /usr/lib/x86_64-linux-gnu/libgstpbutils-0.10.so.0
libgstreamer-plugins-base0.10-0:amd64: /usr/lib/x86_64-linux-gnu/libgstvideo-0.10.so.0
libgstreamer0.10-0:amd64: /usr/lib/x86_64-linux-gnu/libgstbase-0.10.so.0
libgstreamer0.10-0:amd64: /usr/lib/x86_64-linux-gnu/libgstreamer-0.10.so.0
libsqlite3-0:amd64: /usr/lib/x86_64-linux-gnu/libsqlite3.so.0
libxcomposite1:amd64: /usr/lib/x86_64-linux-gnu/libXcomposite.so.1
libxml2:amd64: /usr/lib/x86_64-linux-gnu/libxml2.so.2
libxslt1.1:amd64: /usr/lib/x86_64-linux-gnu/libxslt.so.1
apt-file was a tease to give me the 64-bit packages so I had to do sudo apt-file -a amd64 update to force it to have the 64-bit file list.
Now, let me explain what is all the above:
ldd /path/to/binary: reads a binary and tells you what are the required libraries, symbols, etc.
dpkg -S: search which packages provide a specific installed file.
awk, sed and grep: are modifying the text stream to process only the interesting parts or show the desired output.
|, $(...): the first allows me to pipe the output of a command to another, and the later allows me to execute/evaluate a command before the main ones gets executed.
TL;dr just install these packages:
sudo dpkg --add-architecture amd64 ## adding 64-bits architecture package
sudo apt-get update
sudo apt-get install libgstreamer-plugins-base0.10-0:amd64 libgstreamer-plugins-base0.10-0:amd64 libgstreamer-plugins-base0.10-0:amd64 libgstreamer-plugins-base0.10-0:amd64 libgstreamer0.10-0:amd64 libgstreamer0.10-0:amd64 libsqlite3-0:amd64 libxcomposite1:amd64 libxml2:amd64 libxslt1.1:amd64 libc6:amd64 libdrm2:amd64 libffi6:amd64 libgcc1:amd64 libgl1-mesa-glx:amd64 libglapi-mesa:amd64 libglib2.0-0:amd64 libpcre3:amd64 libstdc++6:amd64 libx11-6:amd64 libx11-xcb1:amd64 libxau6:amd64 libxcb1:amd64 libxcb-dri2-0:amd64 libxcb-dri3-0:amd64 libxcb-glx0:amd64 libxcb-present0:amd64 libxcb-sync1:amd64 libxdamage1:amd64 libxdmcp6:amd64 libxext6:amd64 libxfixes3:amd64 libxrender1:amd64 libxshmfence1:amd64 libxxf86vm1:amd64 zlib1g:amd64
You also need to install the 64-bit kernel.
