I am unable to install mysql workbench community addition on ubuntu 14.04 I am installing latest version by debian file downloaded from server
1. sudo apt-get install gdebi-core
2. sudo gdebi mysql-workbench-community-6.3.3-1ubu1404-amd64.deb
I get following error and it stopped
Unknown media type in type 'all/all'
Unknown media type in type 'all/allfiles'
Unknown media type in type 'uri/mms'
Unknown media type in type 'uri/mmst'
Unknown media type in type 'uri/mmsu'
Unknown media type in type 'uri/pnm'
Unknown media type in type 'uri/rtspt'
Unknown media type in type 'uri/rtspu'
Processing triggers for hicolor-icon-theme (0.13-1) ...
when I run this command
#sudo apt-get upgrade
I get this
You might want to run 'apt-get -f install' to correct these.
mysql-workbench-community:amd64 : Depends: libgl1-mesa-glx:amd64 or
libgl1:amd64
Depends: python-paramiko:amd64 but it is not installable
E: Unmet dependencies. Try using -f.
I tried following
sudo apt-get -f install
and again no luck
Reading package lists... Done
Building dependency tree
Correcting dependencies... Done
The following packages were automatically installed and are no longer required:
gcc-4.8-base:amd64 libasn1-8-heimdal:amd64 libatk1.0-0:amd64
libatkmm-1.6-1:amd64 libavahi-client3:amd64 libavahi-common-data:amd64
libavahi-common3:amd64 libbaloocore4 libbaloofiles4 libbalooxapian4
libcairo2:amd64 libcairomm-1.0-1:amd64 libctemplate2:amd64 libcups2:amd64
libcurl3:amd64 libdatrie1:amd64 libdrm-intel1:amd64 libdrm-nouveau2:amd64
libdrm-radeon1:amd64 libelf1:amd64 libexpat1:amd64 libffi6:amd64
libfontconfig1:amd64 libfreetype6:amd64 libgcrypt11:amd64
libgdk-pixbuf2.0-0:amd64 libgl1-mesa-dri:amd64 libgl1-mesa-glx:amd64
libglapi-mesa:amd64 libglib2.0-0:amd64 libglibmm-2.4-1c2a:amd64
libgmp10:amd64 libgnome-keyring0:amd64 libgnutls-deb0-28:amd64
libgnutls26:amd64 libgpg-error0:amd64 libgraphite2-3:amd64
libgssapi-krb5-2:amd64 libgssapi3-heimdal:amd64 libgtk2.0-0:amd64
libgtkmm-2.4-1c2a:amd64 libharfbuzz0b:amd64 libhcrypto4-heimdal:amd64
libheimbase1-heimdal:amd64 libheimntlm0-heimdal:amd64 libhogweed2:amd64
libhx509-5-heimdal:amd64 libidn11:amd64 libjasper1:amd64 libjbig0:amd64
libjpeg-turbo8:amd64 libjpeg8:amd64 libk5crypto3:amd64 libkeyutils1:amd64
libkidletime4 libkrb5-26-heimdal:amd64 libkrb5-3:amd64 libkrb5support0:amd64
libldap-2.4-2:amd64 libllvm3.4:amd64 libnepomukcleaner4 libnettle4:amd64
libp11-kit0:amd64 libpango-1.0-0:amd64 libpangocairo-1.0-0:amd64
libpangoft2-1.0-0:amd64 libpangomm-1.4-1:amd64 libpciaccess0:amd64
libpcrecpp0:amd64 libpixman-1-0:amd64 libpoppler-qt4-4 libpython2.7:amd64
libpython2.7-minimal:amd64 libpython2.7-stdlib:amd64 libqjson0
libqmobipocket1 libreadline6:amd64 libroken18-heimdal:amd64 librtmp1:amd64
libsasl2-2:amd64 libsasl2-modules:amd64 libsasl2-modules-db:amd64
libsigc++-2.0-0c2a:amd64 libsqlite3-0:amd64 libssl1.0.0:amd64
libstdc++6:amd64 libtasn1-6:amd64 libthai0:amd64 libtiff5:amd64
libtinyxml2.6.2:amd64 libtxc-dxtn-s2tc0:amd64 libwind0-heimdal:amd64
libx11-6:amd64 libx11-xcb1:amd64 libxau6:amd64 libxcb-dri2-0:amd64
libxcb-dri3-0:amd64 libxcb-glx0:amd64 libxcb-present0:amd64
libxcb-render0:amd64 libxcb-shm0:amd64 libxcb-sync1:amd64 libxcb1:amd64
libxcomposite1:amd64 libxcursor1:amd64 libxdamage1:amd64 libxdmcp6:amd64
libxext6:amd64 libxfixes3:amd64 libxi6:amd64 libxinerama1:amd64
libxml2:amd64 libxrandr2:amd64 libxrender1:amd64 libxshmfence1:amd64
libxxf86vm1:amd64 libzip2:amd64
Use 'apt-get autoremove' to remove them.
The following packages will be REMOVED:
0 upgraded, 0 newly installed, 1 to remove and 0 not upgraded.
1 not fully installed or removed.
After this operation, 135 MB disk space will be freed.
