I'm running Ubuntu 14.04, how can I replace the lockscreen with the one on Elementary Luna (Pantheon-Greeter). Thank You!!
Edit: Can anyone do it and confirm it works completely?
user276752
  • 325
  • 13
To install Pantheon Greeter on Ubuntu 14.04,Open terminal and run the commands:
Since libgranite3 (>= 0.2.0) missing in 14.04,so we need the following PPA as well.
sudo add-apt-repository ppa:elementary-os/os-patches
sudo add-apt-repository ppa:elementary-os/daily
sudo apt-get update
sudo apt-get install pantheon-greeter
Note:
After installation remove ppa's:
sudo add-apt-repository -r ppa:elementary-os/os-patches
sudo add-apt-repository -r ppa:elementary-os/stable
sudo apt-get update
Note: Tested and working. refer here
For settings I found a similar link refer Can I replace the default login screen for the Pantheon Greeter?
Ravan
  • 9,567
Add elemantaryrepositary to ubuntu. It is just do not enough install Panthon greeter. Install all other software needed. Use below command to install them.
sudo add-apt-repository ppa:elementary-os/daily && sudo apt-get update && sudo apt-get install pantheon-greeter elementary-theme fonts-open-sans fonts-raleway elementary-icon-theme notify-osd-icons-elementary
open gedit as root, type gksu gedit /etc/lightdm/lightdm.conf
Change the line greeter-session= to look like this greeter-session=pantheon-greeter
Refer this link-Can I replace the default login screen for the Pantheon Greeter?
-2
I don't think you can get the greeter from Luna on to ubuntu 14.04 using that repository. It will point to the Trusty files, so what you'll get is the new pantheon-greeter being developed for elementary os Freya
