In my search libgranite3 (>= 0.2.0) not available for 14.04
refer here
so before installing pantheon we need to add the following PPA(that will install libgranite3):
Open terminal and run the following commands in terminal
sudo add-apt-repository ppa:elementary-os/daily
sudo add-apt-repository ppa:elementary-os/os-patches
sudo apt-get update
sudo apt-get install pantheon-greeter
Note: Remove the PPAs after installation
For reference here
RESULT AFTER TESTING
Reading package lists... Done
Building dependency tree
The following packages were automatically installed and are no longer required:
gir1.2-json-1.0 gir1.2-timezonemap-1.0 gir1.2-xkl-1.0
Use 'apt-get autoremove' to remove them.
The following extra packages will be installed:
apport-hooks-elementary contractor libatk1.0-0 libatk1.0-data libcairo2
libgail-3-0 libglib2.0-0 libglib2.0-bin libgranite-common libgranite3
libgtk-3-0 libgtk-3-common libpango-1.0-0 libpango1.0-0 libpangocairo-1.0-0
libpangoft2-1.0-0 libpangoxft-1.0-0 libwayland-client0 libwayland-cursor0
numlockx
The following NEW packages will be installed:
apport-hooks-elementary contractor libgranite-common libgranite3 numlockx
pantheon-greeter
The following packages will be upgraded:
libatk1.0-0 libatk1.0-data libcairo2 libgail-3-0 libglib2.0-0 libglib2.0-bin
15 upgraded, 6 newly installed, 0 to remove and 119 not upgraded.
Need to get 11.5 MB of archives.
After this operation, 29.7 MB of additional disk space will be used.
Do you want to continue? [Y/n]
