30
I've found several solutions to convert Ubuntu 12.04 Desktop to Server, with the following commands:
sudo apt-get install tasksel
sudo tasksel remove ubuntu-desktop
sudo tasksel install server
apt-get install linux-server linux-image-server
apt-get –purge remove lightdm
I just want to know if it is the same process with Ubuntu 14.04. The reason I need to do this is because I need to install moodle (some people may have other reasons to do this so I hope this helps them too) and it requires to run over Ubuntu Server rather than Desktop. Thanks
NOTE: the following commands are good only to Ubuntu version less/older than 12.04, see Server FAQ, CAUTION: you might end up with a useless system.
Thanks for your answer but I've found you need to add the update line
sudo apt-get update
Also corrected the following line
sudo apt-get -purge remove lightdm
To
sudo apt-get purge lightdm
The full version of the corrected script is below
# update
sudo apt-get update
# install the 'tasksel' package so we can remove the desktop image
# remove the desktop image
# tell tasksel to start the server image setup
# install the server images
sudo apt-get install linux-server linux-image-server
# remove lightdm
# remove all packages no longer required (~400 MB)
sudo apt-get autoremove
muru
  • 207,228
nityan
  • 411
The simple answer is yes, but running the commands you are able to install Ubuntu server. Ensure that you make the following changes to the grub configuration file located at /etc/default/grub:
GRUB_TIMEOUT=10
( Comment out ‘GRUB_HIDDEN_TIMEOUT’ )
GRUB_CMDLINE_LINUX_DEFAULT=”"
GRUB_TERMINAL=console ( only for PC )
Then you can run
sudo update-grub
heemayl
  • 93,925
The assumption that you need to uninstall your Ubuntu desktop and install Ubuntu server is faulty.
However for a real installation its always better to have a minimal installation containing only what you need.
Ubuntu server is just a minimal Ubuntu install with a specific kernel optimized for serving many clients. Instead of a single user in the case of a desktop. any application / Service you can run on your Ubuntu server you can run on Ubuntu desktop
Checking the installation requirements on moodle
We can see that what is needed is:
  • a webserver
  • php support for the webserver
  • a database
tomodachi
  • 15,370
