51
I'm having trouble getting clang++ to work as I compile my code. Specifically, I'm getting a make: clang++: Command not found error.
I've run sudo apt-get install llvm, and also sudo apt-get install build-essential and sudo apt-get update. What do I have to do to get clang++ installed?
Eliah Kagan
  • 119,640
user313944
  • 1,631
Installing the llvm and build-essential packages, as you have done, does not cause clang or clang++ to be installed. For that, you must install one of the clang packages, depending on which version of clang and clang++ you want.
16.04
In Ubuntu 16.04, your options are clang-3.5, clang-3.6, clang-3.7, and clang-3.8.
14.04
In Ubuntu 14.04, your options are clang-3.3 Install clang-3.3, clang-3.4 Install clang-3.4, and clang-3.5 Install clang-3.5.
You can install them in the Software Center, or with:
sudo apt-get update
sudo apt-get install clang-3.n
(Replacing n with the desired sub-version, of course.)
12.04
If you're running Ubuntu 12.04, there's only one package that provides clang and clang++, so it's just called clang Install clang.
Eliah Kagan
  • 119,640
27
18.04 (Bionic)
I visited http://apt.llvm.org/bionic/dists/ (i.e. bionic distributions).
I determined that 6.0 was the latest major version of the toolchain.
I assume that you'll want the linker, lld, also.
# grab the key that LLVM use to GPG-sign binary distributions
wget -O - https://apt.llvm.org/llvm-snapshot.gpg.key | sudo apt-key add -
sudo apt-get update
sudo apt-add-repository "deb http://apt.llvm.org/bionic/ llvm-toolchain-bionic-6.0 main"
sudo apt-get install -y clang-6.0 lld-6.0
This gives you binaries with the following names (and more, probably):
clang-6.0
clang++-6.0
lld-6.0
ld.lld-6.0
It also installs these packages (and more):
llvm-6.0
llvm-6.0-dev
llvm-6.0-runtime
17.04 (Artful)
Same as above. I'll repeat every line for convenient copy-paste.
sudo apt-get update
sudo apt-add-repository "deb http://apt.llvm.org/artful/ llvm-toolchain-artful-6.0 main"
16.04 (Xenial)
The accepted answer already gives instructions for installing clang-3.8 on 16.04, but here's how to get clang-6.0:
sudo apt-get update
sudo apt-add-repository "deb http://apt.llvm.org/xenial/ llvm-toolchain-xenial-6.0 main"
Birchlabs
  • 370
Before proceeding it will be worthwhile to update package information using sudo apt-get update
Installing Clang 9 on Ubuntu 18
sudo apt-get install clang-tools-9
It will also install llvm-9
For more information follow clang documentation.
Installing Clang 10 on Ubuntu 18
sudo apt-get install clang-tools-10
22.04LTS (Jammy)
sudo apt-get install -y clang-14 lld-14
Found latest release here: https://packages.ubuntu.com/jammy/clang-14
Contango
  • 121
