I get the following error when trying to sudo apt-get install Clang++:
Note, selecting 'clang-tidy-4.0' for regex 'Clang+'
Note, selecting 'python-clang-5.0' instead of 'python-clang-x.y'
python-clang-3.5 : Breaks: python-clang-3.6 but 1:3.6.2-3ubuntu2 is to be installed
                Breaks: python-clang-3.7 but 1:3.7.1-2ubuntu2 is to be installed
                Breaks: python-clang-3.8 but 1:3.8-2ubuntu4 is to be installed
python-clang-3.6 : Breaks: python-clang-3.5 but 1:3.5.2-3ubuntu1 is to be installed
python-clang-3.7 : Breaks: python-clang-3.5 but 1:3.5.2-3ubuntu1 is to be installed
python-clang-3.8 : Breaks: python-clang-3.5 but 1:3.5.2-3ubuntu1 is to be installed
python-clang-3.9 : Breaks: python-clang-3.5 but 1:3.5.2-3ubuntu1 is to be installed
python-clang-4.0 : Breaks: python-clang-3.5 but 1:3.5.2-3ubuntu1 is to be installed
                Breaks: python-clang-3.9 but 1:3.9.1-4ubuntu3~16.04.2 is to be installed
python-clang-5.0 : Breaks: python-clang-3.5 but 1:3.5.2-3ubuntu1 is to be installed
I am unsure how to resolve these dependencies and don't know a good workaround for it. I am relatively new to Linux.
I am using Ubuntu 16.04 LTS
Any information would be appreciated. As far as I have been able to read here on the forums I should either remove the culprit program or upgrade it to the version that is needed. But from the error message I am unable to really gather what the culprit is in this case.
Zanna
  • 72,312
Svp
  • 173
The problem is that there is no package Clang++ or even clang++, so apt is treating the given name as a regular expression and trying to install every matching package - many of which conflict with each other:
$ sudo apt-get install --dry-run Clang++
Reading package lists... Done
Building dependency tree
Note, selecting 'clang-modernize-5.0' for regex 'Clang+'
Note, selecting 'libclang-3.6-dev' for regex 'Clang+'
Note, selecting 'python-clang-3.3' for regex 'clang+'
Note, selecting 'python-clang-3.4' for regex 'clang+'
Note, selecting 'python-clang-3.5' for regex 'clang+'
Note, selecting 'python-clang-3.6' for regex 'clang+'
Note, selecting 'python-clang-3.7' for regex 'clang+'
Note, selecting 'python-clang-3.8' for regex 'clang+'
Note, selecting 'python-clang-3.9' for regex 'clang+'
In fact, unlike gcc/g++, clang provides both C and C++ compilers as a single package - you can install a specific version such as clang-3.5 or simply install the highest-priority version for your system via the clang dependency package:
sudo apt install clang
See for example How to install clang++?
steeldriver
  • 142,475
