-1
It gives this error installing VLC and sort of same for the chrome too, can anybody please help?
Reading package lists... Done
Building dependency tree
 vlc : Depends: vlc-nox (= 2.1.4-0ubuntu14.04.1) but it is not going to be installed
       Depends: libsdl-image1.2 (>= 1.2.10) but it is not installable
       Depends: libsdl1.2debian (>= 1.2.11) but it is not installable
       Depends: libtar0 but it is not installable
       Depends: libva-x11-1 (> 1.3.0~) but it is not installable
       Depends: libva1 (> 1.3.0~) but it is not installable
       Depends: libvlccore7 (>= 2.1.0) but it is not going to be installed
       Depends: libxcb-composite0 but it is not installable
       Depends: libxcb-keysyms1 (>= 0.3.9) but it is not installable
       Depends: libxcb-xv0 (>= 1.2) but it is not installable
       Recommends: vlc-plugin-notify (= 2.1.4-0ubuntu14.04.1) but it is not going to be installed
       Recommends: vlc-plugin-pulse (= 2.1.4-0ubuntu14.04.1) but it is not going to be installed
g_p
  • 19,034
  • 59
  • 69
VLC installation problem on Ubuntu 14.04 LTS
This is worked for me
This worked for me assuming we are from Pakistan we might be facing the same problem
hit alt + f2 type additional drivers open the app, this will open the window software & updates go to the ubuntu software tab below change the "download from", I selected the main server. close it
hit ctrl+alt+t (open the terminal) type and enter:
sudo apt-get install vlc
download will begin if its done you can open it by typing:
vlc &
else run
sudo apt-get -f install
which I had to after that, run the
Now it installed for me again to open it you can enter
vlc &
or simply go search it in the home menu
Hope this helps. "
