yEd is a feature rich editor for hierarchical diagrams and flow charts. I would like to install it on Ubuntu. Unfortunately it doesn't appear to be available in the official repositories.
What steps would I have to follow to install yEd on Ubuntu?
There are two ways to install yEd on Ubuntu.
Using the provided graphical installer
yEd comes with an easy-to-use graphical installer that takes care of all the system dependencies (Java, most importantly):
Follow these steps:
chmod +x yEd<...>.sh or by going into the properties menu of your file manager (Properties → Permissions → Allow executing file as program)Manual installation
Navigate to the extracted folder and open yed.jar in java:
java -jar "yed.jar"
To integrate yEd into your system you can create a .desktop launcher under ~/.local/share/applications. E.g.:
$ cat ~/.local/share/applications/yed.desktop
[Desktop Entry]
Encoding=UTF-8
Name=yEd Graph Editor
Comment=Edit graphml files in yed
Exec=java -jar /home/user/applications/yEd/yed.jar %u
Terminal=false
Type=Application
Icon=/home/user/applications/yEd/icons/yicon32.png
Categories=Application;Office
StartupNotify=false
MimeType=application/xml;
NoDisplay=false
Make sure to change the Exec= and Icon= lines according to your system.
If you want to associate yEd's .graphml files (it's not done automatically by the installer), you can use the following script:
#! /bin/bash
Run the script in the root of yEd installation directory
Tested with Ubuntu 18.04
Tested with Ubuntu 22.04 LTS
Create a new mime type definition file
cat >graphml+xml-mime.xml << EOL
<?xml version="1.0"?>
<mime-info xmlns='http://www.freedesktop.org/standards/shared-mime-info'>
<mime-type type="application/x-graphml+xml">
<comment>yEd graphml file (xml format)</comment>
<glob pattern="*.graphml"/>
<generic-icon name="x-application-graphml+xml"/>
</mime-type>
</mime-info>
EOL
Install the new mime definition
sudo xdg-mime install graphml+xml-mime.xml
Install icon (size 48 can be extracted from i4j_extf_2_1aawyej_k3n8ea.ico file)
sudo xdg-icon-resource install --context mimetypes --size 32 .install4j/yEd.png x-application-graphml+xml
Append %F to yEd .desktop file so it is visible in "Open With Other Application" menu
sed -i '/Exec/ s/$/ %F/' ~/.local/share/applications/yEd\ Graph\ Editor-0.desktop
Finally go to file manager, right click, select "Open With Other Application",
click "View All Applications" and select yEd.
