I was bored recently so I decided to download and install drivers from ASUS site. My motherboard is Asus P5K. After downloading the drivers, I messed up the installation somehow (don't remember the details) and now I don't have sound at all!
I'm new to Ubuntu and I don't have a clue how driver setup works. Can you tell me how to bring back the old drivers or how to install this driver? And the first driver worked perfectly, but I was curious about the new driver so I messed up :(
P.S, Ubuntu 14.4
LiveWireBT
  • 29,597
Dario
If you installed the audio drivers, you most likely installed the ALSA package. When ALSA installs, it is set to "global Mute" and you have to open ALSA and take it off mute before your audio can be used. In a terminal type
alsamixer
if command not found, type
sudo apt-get update
sudo apt-get install alsa-utils
and then
alsamixer
and take it off mute.
mchid
  • 44,904
  • 102
  • 162
I don't see a new driver on the support page.
Possible solutions:
  • Restore from your last system backup.
  • Uninstall the old drivers from the ASUS site, e.g. run make uninstall where you ran make install in the instructions to install the drivers (have a look at the corresponding makefiles if uninstall fails), reinstall the corresponsing alsa packages from the repository and probably run update-initramfs -k all -u to be sure that there are no old drivers in the initramfs image.
Remember:
  • If it ain't broke, don't fix it.
  • Have up to date backups. Verify them.
  • Be careful, especially when using root permissions.
    • When installing software/drivers manually: read changelogs and release notes; verify version numbers, timestamps and hashes; read the installation instructions entirely before attempting to install.
tl;dr: Use your brain! Being a beginner is not a valid excuse for being lazy and sloppy.
LiveWireBT
  • 29,597
