I am quite new to LVM and I'm uncertain about what is happening here. I was not the one to initially setup this machine.
There is a harddrive of 1tb in size and an LVM partition of only 50gb in size. I can not figure out how I can use the remaining space of the harddrive.
output of command df -h:
Filesystem Size Used Avail Use% Mounted on
/dev/mapper/vg00-slash 46G 1.4G 42G 4% /
udev 3.9G 4.0K 3.9G 1% /dev
tmpfs 1.6G 236K 1.6G 1% /run
none 5.0M 0 5.0M 0% /run/lock
none 3.9G 0 3.9G 0% /run/shm
/dev/sda1 232M 29M 191M 14% /boot
output of command fdisk -l:
Disk /dev/sda: 1099.5 GB, 1099511627776 bytes
255 heads, 63 sectors/track, 133674 cylinders, total 2147483648 sectors
Units = sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk identifier: 0x00038096
Device Boot Start End Blocks Id System
/dev/sda1 * 2048 499711 248832 83 Linux
/dev/sda2 501758 104855551 52176897 5 Extended
/dev/sda5 501760 104855551 52176896 8e Linux LVM
Disk /dev/mapper/vg00-swap: 3997 MB, 3997171712 bytes
255 heads, 63 sectors/track, 485 cylinders, total 7806976 sectors
Disk identifier: 0x00000000
Disk /dev/mapper/vg00-swap doesn't contain a valid partition table
Disk /dev/mapper/vg00-slash: 49.4 GB, 49429872640 bytes
255 heads, 63 sectors/track, 6009 cylinders, total 96542720 sectors
Disk /dev/mapper/vg00-slash doesn't contain a valid partition table
What I assume I had to do, was create a new partition on /dev/sda to contain the remaining space but when trying to create a new primary partition I am told I can't.
Last sector, +sectors or +size{K,M,G} (499712-501757, default 501757): +800G
Value out of range.
I do not know what I can do now...
When trying to resize the logical volume I get:
# lvresize vg00/slash -L +800g
Extending logical volume slash to 846.04 GiB
Insufficient free space: 204800 extents needed, but only 0 available
# pvdisplay -m
--- Physical volume ---
PV Name /dev/sda5
VG Name vg00
PV Size 49.76 GiB / not usable 2.00 MiB
Allocatable yes (but full)
PE Size 4.00 MiB
Total PE 12738
Free PE 0
Allocated PE 12738
PV UUID WNZba3-bCCs-NmqL-Bc9v-zusy-TtfQ-BpAj3e
--- Physical Segments ---
Physical extent 0 to 952:
Logical volume /dev/vg00/swap
Logical extents 0 to 952
Physical extent 953 to 12737:
Logical volume /dev/vg00/slash
Logical extents 0 to 11784
(parted) print free
Model: VMware Virtual disk (scsi)
Disk /dev/sda: 1100GB
Sector size (logical/physical): 512B/512B
Partition Table: msdos
Number Start End Size Type File system Flags
32.3kB 1049kB 1016kB Free Space
1 1049kB 256MB 255MB primary ext4 boot
256MB 257MB 1048kB Free Space
2 257MB 53.7GB 53.4GB extended
5 257MB 53.7GB 53.4GB logical lvm
53.7GB 1100GB 1046GB Free Space
