How can I make my scanner Epson perfection 3170 running under ubuntu 11.04 ?
When I run "Simple Scan" it said:"No scanner detected".
Thanks
Edit:
after I saw suli8's anwser. I downloaded both rpm:iscan-plugin-gt-9400-1.0.0-1.c2.i386.rpm and iscan-2.10.0-1.c2.i386.rpm
both where transformed+installed with alien. I tried it twice.
$ sudo alien -i iscan_2.10.0-2_i386.deb
Warning: Skipping conversion of scripts in package iscan: postinst postrm
Warning: Use the --scripts parameter to include the scripts.
dpkg --no-force-overwrite -i iscan_2.10.0-2_i386.deb
(Reading database ... 160709 files and directories currently installed.)
Preparing to replace iscan 2.10.0-2 (using iscan_2.10.0-2_i386.deb) ...
Unpacking replacement iscan ...
Setting up iscan (2.10.0-2) ...
Processing triggers for man-db ...
Processing triggers for libc-bin ...
ldconfig deferred processing now taking place
$ sudo alien -i iscan-plugin-gt-9400_1.0.0-2_i386.deb
Warning: Skipping conversion of scripts in package iscan-plugin-gt-9400: postinst postrm
dpkg --no-force-overwrite -i iscan-plugin-gt-9400_1.0.0-2_i386.deb
Preparing to replace iscan-plugin-gt-9400 1.0.0-2 (using iscan-plugin-gt-9400_1.0.0-2_i386.deb) ...
Unpacking replacement iscan-plugin-gt-9400 ...
Setting up iscan-plugin-gt-9400 (1.0.0-2) ...
After rebooting. "Simple Scan" still says: "No scanner detected".
edit2
$ sudo dpkg -i iscan_2.10.0-2_i386.deb
[sudo] password for lindenb:
$sudo dpkg -i iscan-plugin-gt-9400_1.0.0-2_i386.deb
edit3 as a note I'm copying here the original Ronok's response at http://ubuntuforums.org/showthread.php?t=1028064&page=2
1) first see where things stand Is the Scanner USB properly connected to the computer ?
lsusb
Bus 001 Device 007: ID 04b8:0116 Seiko Epson Corp. Perfection 3170 (GT-9400)
2) Check that SANE & XSANE are Present:
sudo apt-get install sane &&
sudo apt-get install libsane &&
sudo apt-get install libsane-extras &&
sudo apt-get install sane-utils &&
sudo apt-get install xsane &&
sudo apt-get install xsane-common &&
sudo apt-get install libstdc++5
3) Check That the system is upto date: System > Administration > Update Manager (or)
sudo apt-get update && sudo apt-get upgrade
4) Then lets see where things stand:
xsane
Get a Pop up Window:
No Devices available
5) To get a list of devices
scanimage -L
No scanners were identified. If you were expecting something different, check that the scanner is plugged in, turned on and detected by the sane-find-scanner tool (if appropriate). Please read the documentation which came with this software (README, FAQ, manpages).
6) See if SANE can see the Scanner ?
sane-find-scanner
found USB scanner (vendor=0x04b8, product=0x0116) at libusb:001:007
7) open and maybe edit this file Check to see that "epson" & epson2" are uncommented (that is with out"#")
sudo gedit /etc/sane.d/dll.conf
8)(with Epson issues all roads seem to lead here) so Go to: http://www.avasys.jp/lx-bin2/linux_e/scan/DL1.do Fill in the form and download: ---> iscan-2.10.0-1.c2.i386.rpm ---> iscan-plugin-gt-9400-1.0.0-1.c2.i386.rpm to the Desktop thats your:
cd ~/Desktop && pwd
9)Get Alien Alien allows you to convert ".rpm" files into Debian ".deb" packages, which can be installed with dpkg.
sudo apt-get install alien
10)Make the ".deb" file from the ".rpm" file (Note in the code-example the "*" takes the place of e.g: "-plugin-gt-9400-1.0.0-1.c2.i386"
cd ~/Desktop
sudo alien -d iscan*.rpm
sudo dpkg -i iscan*.deb
11)Edit the libsane-extras.rules
sudo gedit /etc/udev/rules.d/50-libsane-extras.rules
12)if it is empty add this line:
SUBSYSTEM=="usb", ENV{DEVTYPE}=="usb_device", SYSFS{idVendor}=="04b8", SYSFS{idProduct}=="0116", MODE="0666", GROUP="scanner"
13)
Edit the epson.conf
sudo gedit /etc/sane.d/epson.conf
14) add this line (the USB device ID from step #1 above) at the end:
usb 0x04b8 0x0116
15)Add yourself to the scanner group (adding the scanner group if needed)
System > Administration > Users and Groups > manage groups > unlock > add > check self
16) Do a complete Shutdown & restart the machine
17) Try To get a list of devices again
scanimage -L
device `epson:libusb:001:006' is a Epson flatbed scanner
18)
iscan
