This is the same problem I had for Ubuntu 11.04: Running a epson Scanner perfection 3170 but I cannot apply it for Ubuntu 14.04.
I installed both iscan_2.10.0-2_i386.deb & iscan-plugin-gt-9400_1.0.0-2_i386.deb
$ sudo sane-find-scanner | grep -i epson
found USB scanner (vendor=0x04b8 [EPSON], product=0x0116 [EPSON Scanner]) at libusb:002:003
$ sudo scanimage -L
device `epson:libusb:002:003' is a Epson � flatbed scanner
$ tail /etc/sane.d/epson.conf
usb 0x04b8 0x0116
$ head /etc/udev/rules.d/50-libsane-extras.rules
SUBSYSTEM=="usb", ENV{DEVTYPE}=="usb_device", SYSFS{idVendor}=="04b8", SYSFS{idProduct}=="0116", MODE="0666", GROUP="scanner"
$ groups lindenb
lindenb : lindenb adm dialout cdrom plugdev lpadmin admin saned sambashare scanner
iscan: (could not send command to scanner)
sudo iscan: (could not send command to scanner)
Do you know how to fix this please?
EDIT: Cross posted at: http://ubuntuforums.org/showthread.php?t=2252458
EDIT2: Here is the iscan trace:
$ sudo SANE_DEBUG_EPSON=255 iscan
[sanei_debug] Setting debug level of epson to 255.
[epson] sane_init: sane-backends 1.0.23
[epson] sane_init, ># epson.conf<
[epson] sane_init, >#<
[epson] sane_init, ># here are some examples for how to configure the EPSON backend<
[epson] sane_init, ># SCSI scanner:<
[epson] sane_init, >scsi EPSON<
[epson] sane_init, ># for the GT-6500:<
[epson] sane_init, >scsi "EPSON SC"<
[epson] sane_init, ># Parallel port scanner:<
[epson] sane_init, >#pio 0x278<
[epson] sane_init, >#pio 0x378<
[epson] sane_init, >#pio 0x3BC<
[epson] sane_init, ># USB scanner:<
[epson] sane_init, ># There are two different methods of configuring a USB scanner: libusb and the kernel module<
[epson] sane_init, ># For any system with libusb support (which is pretty much any recent Linux distribution) the<
[epson] sane_init, ># following line is sufficient. This however assumes that the connected scanner (or to be more<
[epson] sane_init, ># accurate, it's device ID) is known to the backend.<
[epson] sane_init, >usb<
[epson] attach_one_usb()
[epson] SANE Epson Backend v0.2.47 - 2006-08-21
[epson] attach(, 3)
[epson] attach: opening
[epson] sane_init, ># For libusb support for unknown scanners use the following command<
[epson] sane_init, ># usb <product ID> <device ID><
[epson] sane_init, ># e.g.:<
[epson] sane_init, ># usb 0x4b8 0x110<
[epson] sane_init, ># And for the scanner module, use the following configuration:<
[epson] sane_init, >#usb /dev/usbscanner0<
[epson] sane_init, >#usb /dev/usb/scanner0<
[epson] sane_init, >usb 0x04b8 0x0116<
[epson] attach_one_usb(libusb:002:002)
[epson] attach(libusb:002:002, 3)
[epson] attach: opening libusb:002:002
[epson] Found valid EPSON scanner: 0x4b8/0x116 (vendorID/productID)
[epson] reset()
[epson] send buf, size = 2
[epson] buf[0] 1b .
[epson] buf[1] 40 @
[epson] w_cmd_count = 1
[epson] r_cmd_count = 0
[epson] r_cmd_count = 1
[epson] receive buf, expected = 1, got = 1
[epson] buf[0] 15 .
[epson] get_identity_information()
[epson] buf[0] 1b .
[epson] buf[1] 49 I
[epson] w_cmd_count = 2
[epson] r_cmd_count = 2
[epson] receive buf, expected = 4, got = 1
[epson] buf[0] 15 .
[epson] code 15
[epson] type 0x01
[epson] level 0x00
[epson] no option equipment installed
[epson] Unknown type or level , using B3
[epson] fbf tlx 0.000000 tly 0.000000 brx 0.000000 bry 0.000000 [mm]
[epson] buf[0] 1b .
[epson] buf[1] 44 D
[epson] w_cmd_count = 3
[epson] r_cmd_count = 3
[epson] buf[0] 15 .
[epson] buf[0] 1b .
[epson] buf[1] 44 D
[epson] w_cmd_count = 4
[epson] r_cmd_count = 4
[epson] buf[0] 15 .
[epson] buf[0] 1b .
[epson] buf[1] 44 D
[epson] w_cmd_count = 5
[epson] r_cmd_count = 5
[epson] buf[0] 15 .
[epson] Max. supported color depth = 8
[epson] request_focus_position()
[epson] Disabling 'Set Focus' support
[epson] buf[0] 1b .
[epson] buf[1] 66 f
[epson] w_cmd_count = 6
[epson] r_cmd_count = 6
[epson] buf[0] 15 .
[epson] code 15
[epson] scanner model:
[epson] close_scanner(fd = 0)
[epson] sane_get_devices()
(end)
