I cannot get my scanner to work on Ubuntu 17.10
I followed the steps here: Running a epson Scanner perfection 3170
sudo sane-find-scanner
says
found USB scanner (vendor=0x04b8 [EPSON], product=0x0116 [EPSON Scanner]) at libusb:001:006
but scanimage -L or sudo scanimage -L says;
No scanners were identified. If you were expecting something different,
check that the scanner is plugged in, turned on and detected by the
sane-find-scanner tool (if appropriate). Please read the documentation
which came with this software (README, FAQ, manpages).
Can anyone advise how to diagnose?
Same problem exists in the latest openSUSE Leap 42.3 (I run dual boot).
When I used openSUSE 12.3 and Ubuntu 10 this scanner worked 'out of the box'. What has changed since?
