I have installed Ubuntu 14.04 on my DELL Inspiron 15R.
Since I have installed it, my fan is constantly spinning, even I do absolutely nothing. I found this post and I decided to install i8kutils. Just after I installed it, my fans are now not spinning at all!! This is very dangerous for my laptop... If I run i8kfan -1 2 my fan is spinning for 1-2 seconds in full power, and then stops again. What I should do?
I also tried the following that exist in this answer:
Put ENABLED=1 in /etc/default/i8kmon
Put set config(auto) 1 in /etc/i8kmon.conf
UPDATE:
Please also find the output of this command $ /usr/bin/i8kmon --verbose here
ps1: I should mention that my laptops fans work flawlesly when using windows.
ps2: I also know that there are numerous similar questions out there. I spent many hours studying them and I couldn't find any good answer. Therefore, I am seeking for a good answer, than closing down my question as duplicate.
Jim Blum
  • 1,437
  • 20
  • 24
Finally, I found it (I think :p). The site mentioned in the question says that the configuration should be copied at the file: /etc/i8mon.
However, they should be written here: ~/.i8kmon instead. And I think it works fine this way.
Editor's Note
The actual error was in the forum post which OP was following. Although the author intended to say to change in /etc/i8kmon file, They mistakenly wrote /etc/i8mon instead in the code section. Since, OP was following the code, the configurations didn't work.
OP saved the configs in ~/.i8kmon and that worked because user's config stored in ~/ is preferred than the ones in /etc and that way it was overriding the default configs. So, OP's assumption is wrong. Both /etc/i8kmon and ~/.i8kmon would work. The error was in somewhere else.
Jim Blum
  • 1,437
  • 20
  • 24
