Does running i8kmon, thermald, and sensors simultaneously have known resource contention issues that cause fans to start spinning at lower temperatures than the thresholds I've configured? Is getting Dell laptop fan speeds and noise under control a solved issue?
I'm running Ubuntu 20.04 on a Dell Precision M6600. I'm using i8kmon and still get fans spinning at higher RPMs triggered at lower temperatures than the thresholds I've configured. I've read these posts and others. All solutions are temporary, at best.
I've disabled BIOS fan control with smm,[dellfan][0], [dell-bios-fan-control][1]
Hardware Sensor Indicator, i8kctl and sensors output all show temperatures below what should trigger any fan activity.
i8kctl output: 1.0 A18 J59D4S1 53 1 1 3413 3034 -1 -1
sensors output:
dell_smm-virtual-0
Adapter: Virtual device
Processor Fan: 3034 RPM
Video Fan:     3410 RPM
CPU:            +53.0°C
Ambient:        +52.0°C
SODIMM:         +47.0°C
SODIMM:         +47.0°C
SODIMM:         +47.0°C
GPU:            +62.0°C
BAT0-acpi-0 Adapter: ACPI interface in0: 12.68 V
curr1: 1000.00 uA
coretemp-isa-0000 Adapter: ISA adapter Package id 0: +55.0°C (high = +86.0°C, crit = +100.0°C) Core 0: +54.0°C (high = +86.0°C, crit = +100.0°C) Core 1: +48.0°C (high = +86.0°C, crit = +100.0°C) Core 2: +55.0°C (high = +86.0°C, crit = +100.0°C) Core 3: +50.0°C (high = +86.0°C, crit = +100.0°C)
acpitz-acpi-0 Adapter: ACPI interface temp1: +25.0°C (crit = +107.0°C)
"Hardware Sensor Indicator" output
smcnally
  • 470
