I'm trying to get a Tascam US-122L USB 2.0 Audio/MIDI Interface working with jackd.
The correct kernel modules seem to load when I plug the device in:
$ lsmod | grep us122l
snd_usb_us122l 23020 0
snd_usbmidi_lib 29476 1 snd_usb_us122l
snd_hwdep 17709 2 snd_usb_us122l,snd_hda_codec
snd 78957 18 snd_usb_us122l,snd_usbmidi_lib,snd_hda_codec_analog,snd_hda_intel,snd_hda_codec,snd_hwdep,snd_pcm,snd_rawmidi,snd_seq,snd_timer,snd_seq_device
ALSA seems to detect the card:
$ cat /proc/asound/cards
0 [SB ]: HDA-Intel - HDA ATI SB
HDA ATI SB at 0x60000000 irq 16
1 [US122L ]: USB US-122L - TASCAM US-122L
TASCAM US-122L (644:800e if 0 at 001/004)
Also:
$ aplay -L
default
Playback/recording through the PulseAudio sound server
sysdefault:CARD=SB
HDA ATI SB, AD198x Analog
Default Audio Device
front:CARD=SB,DEV=0
Front speakers
surround40:CARD=SB,DEV=0
4.0 Surround output to Front and Rear speakers
surround41:CARD=SB,DEV=0
4.1 Surround output to Front, Rear and Subwoofer speakers
surround50:CARD=SB,DEV=0
5.0 Surround output to Front, Center and Rear speakers
surround51:CARD=SB,DEV=0
5.1 Surround output to Front, Center, Rear and Subwoofer speakers
surround71:CARD=SB,DEV=0
7.1 Surround output to Front, Center, Side, Rear and Woofer speakers
dmix:CARD=SB,DEV=0
Direct sample mixing device
dsnoop:CARD=SB,DEV=0
Direct sample snooping device
hw:CARD=SB,DEV=0
Direct hardware device without any conversions
plughw:CARD=SB,DEV=0
Hardware device with all software conversions
usb_stream:CARD=SB
HDA ATI SB
usb_stream:CARD=US122L
TASCAM US-122L
The card also shows up in qjackctl, but when I select it as interface and try to start jackd, I get the following error:
16:37:20.811 D-BUS: JACK server could not be started. Sorry
Cannot connect to server socket err = No such file or directory
jack server is not running or cannot be started
Fri Jun 20 16:37:20 2014: Starting jack server...
Fri Jun 20 16:37:20 2014: JACK server starting in realtime mode with priority 10
Fri Jun 20 16:37:20 2014: control device hw:1
Fri Jun 20 16:37:20 2014: Acquired audio card Audio1
Fri Jun 20 16:37:20 2014: creating alsa driver ... hw:1|hw:1|1024|2|44100|0|0|nomon|swmeter|-|32bit
Fri Jun 20 16:37:20 2014: ERROR: ALSA: Cannot open PCM device alsa_pcm for playback. Falling back to capture-only mode
Fri Jun 20 16:37:20 2014: ERROR: Cannot initialize driver
Fri Jun 20 16:37:20 2014: ERROR: JackServer::Open() failed with -1
Fri Jun 20 16:37:20 2014: ERROR: Failed to open server
Fri Jun 20 16:37:21 2014: Saving settings to "/home/kraxor/.config/jack/conf.xml" ...
16:37:36.683 Could not connect to JACK server as client. - Overall operation failed. - Unable to connect to server. Please check the messages window for more info.
Tried to modify /etc/security/limits.conf and ~/.asoundrc according to the answer to this question, but it didn't solve the problem. Currently they look like this:
$ cat .asoundrc | grep -v \#
pcm.!usb_stream {
@args [ CARD ]
@args.CARD {
type string
default "1"
type usb_stream
card $CARD
ctl.!usb_stream {
@args [ CARD ]
@args.CARD {
type string
default "1"
type hw
card $CARD
$ cat /etc/security/limits.conf | grep -v \#
@audio - rtpio 99
@audio - memlock unlimited
@audio - nice -10
The same happens with Xubuntu 14.04 and Ubuntu Studio 12.04.
Any suggestions are greatly appreciated. This card should be supported as far as I know.
