I've just started using Ubuntu 13.04, but I can't seem to get my sound card (Tascam US-122L) up and running.
I'vce tried many tutorials, but none satisfying. Strangely, at some point, I got the computer to detect my sound card, as it got listed. But a minute later, it was gone (also even then I couldn't get it to play music)
Is there a way of installing the hardware? I also tried to install the Windows driver using WINE, but that gave an error...
lsusb output:
Bus 001 Device 002: ID 8087:0020 Intel Corp. Integrated Rate Matching Hub
Bus 002 Device 002: ID 8087:0020 Intel Corp. Integrated Rate Matching Hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 003: ID 13d3:5130 IMC Networks
Bus 002 Device 007: ID 0644:800e TEAC Corp. TASCAM US-122L
Bus 002 Device 006: ID 046d:c058 Logitech, Inc. M115 Mouse
I seem to get some response, but no sound...
Result from aplay -L:
default
   Playback/recording through the PulseAudio sound server
   sysdefault:CARD=MID
HDA Intel MID, CONEXANT Analog
   Default Audio Device
   front:CARD=MID,DEV=0
   Front speakers
   surround40:CARD=MID,DEV=0
   4.0 Surround output to Front and Rear speakers
   surround41:CARD=MID,DEV=0
   4.1 Surround output to Front, Rear and Subwoofer speakers
   surround50:CARD=MID,DEV=0
   5.0 Surround output to Front, Center and Rear speakers
   surround51:CARD=MID,DEV=0
   5.1 Surround output to Front, Center, Rear and Subwoofer speakers
   surround71:CARD=MID,DEV=0
   7.1 Surround output to Front, Center, Side, Rear and Woofer speakers
   dmix:CARD=MID,DEV=0
   Direct sample mixing device
   dsnoop:CARD=MID,DEV=0
   Direct sample snooping device
   hw:CARD=MID,DEV=0
   Direct hardware device without any conversions
   plughw:CARD=MID,DEV=0
   Hardware device with all software conversions
   usb_stream:CARD=MID
HDA Intel MID
   usb_stream:CARD=US122L
   TASCAM US-122L
   hdmi:CARD=Generic,DEV=0
HD-Audio Generic, HDMI 0
HDMI Audio Output
   dmix:CARD=Generic,DEV=3
   dsnoop:CARD=Generic,DEV=3
   hw:CARD=Generic,DEV=3
   plughw:CARD=Generic,DEV=3
   usb_stream:CARD=Generic
HD-Audio Generic
Lastly cat /proc/asound/cards:
0 [MID            ]: HDA-Intel - HDA Intel MID
                  HDA Intel MID at 0xd5200000 irq 48
1 [US122L         ]: USB US-122L - TASCAM US-122L
                  TASCAM US-122L (644:800e if 0 at 002/007)
2 [Generic        ]: HDA-Intel - HD-Audio Generic
                  HD-Audio Generic at 0xd0040000
I've still haven't found the correct solution, sometimes it recognises my TASCAM, but often not, I can't seem to find the reason why sometimes it does and when it doesn't. Now if he recognises it, I still can't get it to play any sound. I get the above mentioned responses from cat /proc/asound/cards, but when trying pavucontrol, No Tascam to be found...
So I guess my question expands more then I thought:
- How do I get my computer to recognise the card each time
- If the card is recognised, how do I tell the computer to use the card for audio applications..
When following the advice of using next command:
speaker-test -D usb_stream:CARD=US122L
I get:
speaker-test 1.0.25
Playback device is usb_stream:CARD=US122L
Stream parameters are 48000Hz, S16_LE, 1 channels
Using 16 octaves of pink noise
Access type not available for playback: Ongeldig argument
Setting of hwparams failed: Ongeldig argument
(ongeldig argument is dutch for invalid argument)
So far I've tried:
http://wiki.briata.org/doku.php?id=testing_us122l_under_linux the links referred in that document
