42
How to do this manually, not installing any tools?
muru
  • 207,228
Rulet
  • 421
6 Answers6
40
This is my way:
  • Before 13.10:
    sudo -H gedit /lib/plymouth/themes/default.grub
  • 13.10 and later:
    sudo -H gedit /lib/plymouth/themes/ubuntu-logo/ubuntu-logo.grub
  • 16.04 and later:
    sudo -H gedit /usr/share/plymouth/themes/ubuntu-logo/ubuntu-logo.grub
  • 17.10 and later:
    sudo -H gedit /usr/share/plymouth/themes/default.grub
And change the grub background color as you want, in my case I change grub background to black (0,0,0)
if background_color 0,0,0 ; then
   clear
fi
Then, update grub
sudo update-grub
Please note that: there should be a space after the color value, other wise you will always get a black background. And as a gift, try using this value 35,00,60.
MDMower
  • 850
FireHeron
  • 401
It's very simple:
gksu gedit /lib/plymouth/themes/text.plymouth
and change black value with your color, in my case #000000 is black
black=0x000000
Regards
Ok. I've decided to write the answer. I took instructions from here
In my case screen resolution is 1440X900. Somebody says that changing grub window resolution to actual resolution of monitor makes boot faster(but I don't see this take effect in last versions o Ubuntu). So I've changed and uncommented one line in /etc/default/grub to this:
GRUB_GFXMODE=1440x900
Then to change purple background of grub I created the image, in my case just black image with 1440X900 resolution and put it in /boot/grub. So my file is:
/boot/grub/gbackground.jpg
Then I've edited again /etc/default/grub and puted a line in it:
GRUB_BACKGROUND=/boot/grub/gbackground.jpg
then I updated grub configuration with command:
sudo update-grub
That's all. Now grub background is black.
Kris Harper
  • 13,705
rulet
  • 331
I would first get your image, then bring up Terminal type
sudo nautilus
copy or cut image into /boot/grub.
Open the terminal and type
sudo update-grub
There you go.
Seth
  • 59,332
This is an excerpt from The Community Documentation on Grub2
Turning off the splash image: This may make viewing the terminal easier.
1.Press "c" to go to the command line and then type: set color_normal=white/blue or the color combination you wish to use.
2."black" as the second entry retains the menu's transparency and should be avoided as a selection if the user wants to work with a solid background color.
I wrote a ruby script to do the same. It actually edits /etc/default/grub and adds a custom background to it. Here: https://github.com/4p00rv/grub-background-changer
Apoorv
